Question about OKI B4350 Laser Printer
  • adicostenco Jun 25, 2008
    I HAVE AN OKI page 12 i/n printer that display to me the "tonersns" error message. What can i do?
    Problem Solver:
  • 8 Answers
This sounds like it could be a "toner Sense" error / try removing the drum unit and cleaning the 6 contacts on the left inside of the printer
Posted on Apr 12, 2008
It keeps flashing check image drum drum missing, i had paper jam took out drum to remove it then replaced it but keeps flashing this message
Some drum units are "chipped" to prevent the rebuilding of of them and it's possible yours is one of these. Removing the drum, once installed, may have triggered this error message. Try emailing Oki about this; in the past they were pretty good about responding to customer problems while I was still involved with servicing these and other printers.
Mar 07, 2011 | OKI B4350 Laser Printer
Changed drum July 2010, display panel continued to say change drum, but was printing fine until now the printer stops printing in the middle of a report, I have to open and shut the "hood"...
When you change the drum you must reset the drum count.
1: press ONLINE button once. The lcd display will read offline.
2: press MENU button until the lcd display reads MAINT. Menu.
3: press ITEM+ button twice. The lcd display will read drum count reset.
4: press SELECT button once. this will save the drum count reset.
5: press ONLINE button once. You will notice the Change Drum Message
has disappeared. You should be able to print at this time.
Good Luck
Feb 23, 2011 | OKI B4350 Laser Printer
Printer still say need new drum even after being replaced
You need to reset the drum count. take the printer offline by pressing the online button. next scroll down on the menu button til you get to Maint. Menu. Next press Item+ button 2 times. LCD should say Drum count reset. next press select button.this will save the option. next press online button
to put the printer back online. you should be ok to print
Good Luck
Screen says change drum
Your printer is telling you it needs a new drum. Go to a search engine (Google or similar) and type:
oki b4350 drum
The results will show you where you can purchase a replacement. They look to be priced between £115 and £160. The replacement should have instructions on how to fit it.
Best of luck.
Nov 29, 2010 | OKI B4350 Laser Printer
Error tonersns
The toner leak can cause the optical pair responcible for the toner sencing to become dirty. The easiest way to try and rectify this is to vacuum clean the area under the drum unit. At the left side of that area there is a small lever with the magnet in it. Check if it moves smoothly. Vacuum clean everything around that lever. There can be some other reasons worth to check. I put them in this article: It's all in Russian but using online translators and looking at the pictures you'll be able to catch the idea of what should be checked.
Jul 24, 2009 | OKI B4350 Laser Printer
Computer shuts off when a document is about to print.
first you should un install your driver,then install it again.
Jun 26, 2009 | OKI B4350 Laser Printer
I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Jun 03, 2009 | OKI B4350 Laser Printer
When printing all I get is a message saying invalid data (printer B4300)
I had same problem and when I installed OKI B4350 (PCL) driver it started working fine.
Before I had OKI B4350(PS) driver installed and it gave me invalid data error everytime I've pressed print.
I hope this works for you too.
May 22, 2009 | OKI B4350 Laser Printer
Drum change
Step 1. Open Top Cover.(Press the oval button RHFront)
Step 2. Tilt Drum Unit by lifting slightly at the front.(The Toner cartridge sits in the top of this)
Step 3. Remove Drum Unit by lifting straight up.
Step 4. Insert "NEW" Drum Unit. (Steps 3 and 2 in reverse order and direction(s))
May 19, 2008 | OKI B4350 Laser Printer
OKI Printer B4350
The Solution is:
You must have the Oki Monitor Software installed
When you enter in to the software you have a button that say "Maitenace", then you have a option that says " Reset Drum Counter" or somthing similar. Click on the option and the message disappear from the display.
Sorry my bad english
Nov 23, 2007 | OKI B4350 Laser Printer
OKI B4350 Laser Printer Logo
802 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
