Question about RCA TruFlat 27F520T 27" TV
Only half the horziontal screen is appearing (1/2 screen). My TV is only a few years old. This should not be happening...
  • 91 Answers
Ok,if the top or bottom is missing,that would be loss of vertical scan,very unlikely symptom would be half of the left or right,which would be horiz scan. Please check another source,or simply press the menu key and see if that is ok,otherwise the set will need a deflection circuit repair with a range of $75 to $125.........I can also assist with guiding you to repair if you have technical ability?
Posted on Jun 02, 2010
Phillips flat screen tv left half of screen is black right side is dim and flickering
Is your tv less than a year old? You need to call Phillips and see if it is covered under warranty. If that is not the case you need to get a few estimates. You want to know if it will be cheaper to repair or replace your tv set.
1 888-744-5477 Phillips customer service number
Aug 14, 2016 | Televison & Video
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
I HAVE A LG50PQ30 PLASMA TV,WHICH IS JUST OVER A YEAR OLD AND OUT OF WARRANTY. AFTER THE TV HAS BEEN ON FOR A FEW HOURS THERE IS HORIZONTAL LINES APPEAR ABOUT 6 INCHES FROM THE TOP OF THE SCREEN IT STARTS...
Hello that's a 2010 model set. It sounds like the y sustain board is failing (part # EBR61855101), it usually starts with bad connections on it. A screen shot would be helpful...thanks
Apr 28, 2017 | LG 50PX5D 50 in. Plasma HDTV
The screen has gone dim
If this has happened over time, then this is not so unusual for a 5 year old projection TV. If happened suddenly then there is a problem in the video circuit. The best thing would be have a technician look att he TV. Please take a few moments to rate my answer. Thanks...
Nov 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture No sound
how did you remove the stand attached to the tv? But i have heard of this happening before too..They tend to just die..
Dec 23, 2008 | TruTech PM1919BXA1 19 in. LCD TV
Black Rectangle appears on bottom half of screen
Go into your setup menu and turn off closed captioning. The box is there for some channels even though no text is being sent. If you need to keep the closed captioning, try selecting a different mode for it.
Sep 15, 2008 | Toshiba 24AF43 24" TV
My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
Nov 18, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
RCA TruFlat  27F520T 27" TV Logo
98 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
