Question about Acer Aspire 3000 Notebook
When you move the computer working under external
When I move the computer working under external power the power is interrupted, have to jiggle power cord connection to get power back, need a permanent fix
    Sergeant:
    Champion:
  • 452 Answers
Issue with the ac jack. It has a loose connection. you will need to open up the laptop and remove the board to re-solder the AC jack.
Posted on Jun 02, 2010
USB not recognised in computer section?
Try connect any battery-operated external USB device (eg MP3 player, etc.) to the USB port. Does it work? If does, so it is interrupted +5V power supply of USB port on your notebook.
Mar 16, 2015 | Acer Aspire 5335-2257 Notebook
Truck won't start unless i jiggle wires under dash.
I doubt it unless you are moving the wires coming out of the switch.
Sounds like a bad connection or broken wire in the harness you are moving around.
It could involve the neutral safety switch and the harness you are moving could come from that switch.
Jan 11, 2013 | Cars & Trucks
G Drive Disappears
if the G drive is a external hard disk ..check the power for it ..and the cables ..When the power it is out or the cable connection interrupted the drive will no longer be available on the computer drives folder..
If the hard disk is still operable ..just check teh connections ..and will work ..Also try to change the usb port cause some of them may not support it .Always wait the computer to find it and install it first and only look for it after the computer will say the device is installed and ready to be used.
Dec 28, 2011 | Computers & Internet
My physical formatting of my 1tb external hard drive was interrupted. will it damage the internal programs and affect the good working condition of my external hard drive? i'll wait for your...
It'd help if you could say what kind of interruption you experienced. As long as its working now, I\d suggest you copy all your data onto another storage device and do another format. It'll take care of any bad or corrupted cluster that might've formed. Your data should be fine.
Mar 16, 2011 | Buffalo Technology DriveStation HD-HC500U2...
Hi i'm from greece and i bought a hitachi simple drive external hard drive 1 tb about 4 months ago it worked fine but now suddently it stopped . i tried to take it of the power and i also removed the cable...
you must have short in the wire hooked up to external try jiggling the base of wire pluged up to port on the external see if you see the light on hard flicker on off if thats the case its your wire for right intell you get a new wire prop something underneath wire intell you see the light stay on.
Feb 24, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
About 3 times a day the external battery pack for the computer beeps really fast. Then stops.
Most "desktop" computers do NOT have an exernal battery pack. If your does, that's OK.
The "beeps" probably occur when the AC power from the wall-outlet is interrupted (or is cut-off). The charge in the battery continues to supply power to your computer -- so, your computer does NOT crash.
Jan 13, 2010 | HP Pavilion M9040N Elite Desktop PC
When i turn the power on at the plug it clicks the green power light on and off on its own without powering up
This is probably normal IF you are interrupting the power externally.
The processor in the monitor is just reseting itself before setting the power relay into the off mode.
Oct 17, 2009 | Samsung SyncMaster 400PN Monitor
Western Digital external USB 2.0 Problem
Buy an External USB 2.0 Hub with the 5.0V power supply. I have a TARGUS 4 Port Hub. MY WD2500XMSB works fine thru the HUB, but will not work using any cable (even the one that came with it) when directly connected to the USB port on my computer. The power consumption of passports sometimes exceeds the .5 milliwat rating for the ports and ccause the port power to interrupt (see USB 2.0 specifications). The external hubs with external power have a higher power output usually an can power the passport drives. CW Rumsey
Oct 07, 2009 | Western Digital 250GB MyBook External USB...
Acer Aspire 3000 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
