Question about Dometic Rooftop RV Air Conditioner
Have a coleman mach unit that never cools correctly. If you run on low with thermostat halfway down it will keep running. If you run it on high, it acts like the coil is freezing up and barely blows air. I assume it is low on charge. Is there no way to add a charge? We have had our rv only 2 years and they replaced the unit once already.
  • Dometic Master
  • 6,674 Answers
It may also be an obstruction in the ducting. When the forced air is restricted somewhere, it will freeze the coils, and compressor shuts down, until frost is gone, then starts back up and will repeat that all day. I'm thinking that the restriction doesn't affect it as much when fan on low. I'm going to assume this is a ducted system. If I'm right, first, make sure all ceiling ducts are open and if not, open them all up full and see if that changes anything. If it does, you've solved the problem. If it doesn't, shut unit down, remove air filter at ceiling, and then restart unit on high fan. Where the divider is between return air and forced air, carefully look up there with a flashlight and see, as well as feel, very carefully around the edges of that divider for cool air coming in to mix with return/warm air. If you feel quite a bit of cool getting through, shut the unit off again, and use foil tape to seal it up well, then retry it. If not a noticeable amount leaking through, remove the rest of the screws holding that ceiling assembly up, and lower it down as far as you can. Now look at the ducts that go into the ceiling for forced air and make sure they are wide open and no rubber roof hanging in them, or tape or anything else that may restrict flow at all. That is often where you will find that the rectangular opening has been restricted, and will cause that problem as well. If there's rubber roof , or similar in the way, carefully cut it out of there and apply foil tape over anything loose or even gaps into ceiling or roof area, and anywhere else. You want all the forced air going into a wide open duct and nowhere else. Hope that helps. Only other thing you may want to confirm first as well, would be that you do have 115-120 vac, hydro required, going to it. Only other test after that would be an amp draw test, that would require a clamp on amp-meter. My guess is that it's an obstruction in forced side. Keep me posted will ya?
Posted on Jun 25, 2010
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Sep 07, 2010 | Coleman Mach III Air Conditioner
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
Coleman Mach 15 AC just quit. no compressor sound, no fan
If this is a ducted unit, check the thermostat. It has a fuse for protection that may have blown. If the fuse is fine and you have power to the upper units control box, check for 120V incoming power at the control box and also check for incoming 12V on the Yellow and GH wires when tstat is set to high cool.
Hope this helps.
Jun 26, 2009 | Coleman Mach 15 Air Conditioner
At a State park... AC freezing up
If the unit is low on freon, there should be visible signs of leaking somewhere in the upper unit. Are you running the system on Low Cool? This will often times cause the AC to freeze up because the condenser fan and the evaporator fan are on the same motor. If you run the system on low cool, you are not getting enough air movement over your condenser to effectively warm up the freon and thus causing the system to freeze. Turn it to high and adjust the thermostat if it is too cold, this should help.
Jeff
Jun 25, 2009 | Coleman Mach 15 Air Conditioner
Coleman rv rooftop unit, fan runs in on but in auto nothing works
R = HOT 12V
W= WHT- GND
Y = YELLOW / POSSIBLE THERMOSTAT
G= GRND FOR THERMOSTAT
f = FAN
F=FAN
aSSUMING THIS IS A TWLVE VOLT SYTEM- The two f's Would be fan control intake and exhaust - fan direction
White is always ground and so is green.. green is more of a static ground where white is a load grnd.
Red is always hot. in low voltage
I hope this helped. No instructions in kit?
May 18, 2009 | Coleman Mach III Air Conditioner
HAVE A COLEMAN MODEL DRHSO601CB --- THE UNIT WILL RUN FINE FOR SEVERAL HOURS WITH GOOD COOLING AND THEN PERIODICALLY THE TROUBLE LIGHT WILL COME ON THE THERMOSTAT AND THE UNIT HAS SHUT DOWN. TO RESTART -...
You may have a low pressure or high pressure switch tripping out the board as well. You might try cleaning both the indoor (evaporator) coil and the outdoor (condensing) coil. Be sure to turn off the power source before servicing this.
Jun 30, 2008 | Coleman Heating & Cooling
Compressor tries to turn on but cant.
Try changing out the start up and run capacitors for the compressor.
Jun 24, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
143 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
