Question about Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw
Table saw cuts off
When I turn my saw on, it runs for about 2 -3 seconds, then cuts off. I push the reset button and it does the same thing.Jet 10 inch 1.5 HP.
  • 59 Answers
Probably the overload trip is set to too low a current. Either this or it is faulty.
It is just possible that there is dust in the contacts which causes a bad contact but it is more likely to be the overload trip.
Posted on Jun 03, 2010
Overload reset button on porter cable 10 in table saw
Why this is in sewing machines I will never know.
But this is an example of pushing a saw beyond it's limits. At best you should have cut one post, shut the machine off and let it cool... then go for the next. (Better yet get a friend with a saw mill saw the thing down for you)
I believe you have burned out your motor. Off the store you go....for a new one.
Oct 25, 2013 | Sewing Machines
I have been using my Craftsman 10" Table Saw to
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Mar 02, 2011 | Craftsman 10" Table Saw
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get...
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Oct 15, 2010 | Garden
While cutting a piece of scrap plywood on my Craftsman 10" table saw, I accidentally cut through a bolt and it caused my saw to shut off. I pushed the reset button several times, but it doesn't feel as...
First off the saw will have to cool down and then the reset button will take some major force to reset. You should hear a distinct click when it does...
heatman101
Sep 20, 2010 | Craftsman 10" Table Saw
Saw kicked out on overload,reset buttion will not reset
did it trip your outlet breaker? check breaker with volt ohm meter. hope the motor didn't go to ground.
Jan 19, 2010 | Jet 708663PK JTAS-10XL50-W1 10-Inch Left...
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Oct 06, 2009 | Craftsman 10" Table Saw
No power after last cut
I have seen reset buttons not work because they are full of saw dust, Take the cover off the reset button and vacuum or blow it out with compressed air, good luck, cb
May 05, 2009 | Jet 708315LSB 10" Benchtop Tablesaw with...
My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Apr 25, 2009 | Skil 10" Table Saw 3400
Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw Logo
253 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
