Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Handset will not charge
Recently purchased this unit on May 31, 2010. I charged the unit for at least 24 hours. Tried to connect the unit to telephone line. Nothing occurred. Could not get the screen to display a message longer than 15 seconds. It kept showing "low battery, charge." Well, I tried charging it again and nothing but the same message. Is this a useless unit? How can I go about getting a replacement that actually works?
  • 532 Answers
Firstly, try to use another charger, if the problem continue, you can replace the battery of the phone and if this still continue replace the charging port with a good one .
Posted on Jun 02, 2010
How do i get volume on my binatone 3325 handset
Press C/8 to unmute the microphone.
complete installations
Plug the power adapter
& line cord
into the base station.
Plug the power adapter into a 230Vac, 50Hz
mains socket, the other end of the line cord
into your telephone line socket.
Warning: Always use the line cord provided in the box.
Other line cords may not be compatible and may not work.
Warning: Only use the power adapter supplied.
Others will result in non-compliance with the safety
specification EN60950, and will invalidate any approval
given with this apparatus.
Warning: The Base unit needs mains power for
normal operation, not just for charging the handset batteries.
Installing and charging the batteries
Slide open the battery compartment cover.
Place the 2 batteries with the correct polarity,
as shown.
Slide the battery compartment cover back.
Put the handset on the base and charge for
15 hours before first time use. The handset
beeps when charging starts.
Warning: Only use the AAA size NiMH rechargeable
batteries.
If you have a Broadband Line
If you connect your telephone to a line with a broadband connection, you will need to
insert a micro-filter between the telephone and the telephone line, otherwise you may
get interference between the telephone and the broadband, which could cause
problems.
In a home with broadband, every telephone must have a micro-filter connected, not just the one at the telephone point that your modem is connected to.
If you need more broadband micro-filters, contact your broadband provider.
Connection and Conditions for use:
You can connect your phone to a direct exchange line (DEL) on a local
exchange with its own phone number; to an extension socket
connected to a DEL; or to an extension on an approved compatible
PBX. Do not connect as an extension to a payphone.
The ringer equivalence number (REN) of all equipment (phones, fax
machines, modems, etc.) connected to an exchange line must not add
up to more than 4, otherwise one or more of them may not ring and/or
answer calls correctly. This phone has a REN of 1, and most other
telephones have a REN of 1 unless marked otherwise.
Handset - Base Connection
1) When purchased, all handsets are already registered to the base unit
and should link to it when they are all powered up.
2) To use your cordless handset and base unit together, you must be
able to establish a radio link between them. The signal between the
handset and the base is in accordance with the normal standards for
a DECT phone: Maximum range up to 300 metres outdoors or 50
metres indoors. Be aware that:
> Any large metal object, such as a refrigerator, mirror or filing cabinet,
between the handset and the base unit may block the radio signal.
> Other solid structures, like walls, may reduce the signal strength.
> Other electrical equipment may cause interference and/or affect the range.
3) Do not place close to another telephone, a TV or audio equipment - it
may cause interference.
4) Out of Range warning. If you hear a warning tone during a call,
and/or the sound in the earpiece becomes faint or distorted, you may be
going out of range of the base unit, so move nearer to the base unit
within 20 seconds, otherwise the call may be cut off.
Jul 20, 2014 | Lands Phones
Don't I have to connect the phone to a telephone line? I don't see where i can place a phone wire in the phone. Also, I have the handset in the base but it doesn't say that it is registering. It keeps...
Often the line cord connection is on the back of the base unit or underneath, usually near where the AC cord plugs into the base unit that powers it. The handset needs to charge before it will be ready to use, sometimes for 12 hours. If after charging, it still is not registered automatically then try manually registering it to the base unit per the directions in the manual.
Dec 09, 2010 | Uniden Cordless Phone
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Stevie
Feb 14, 2010 | Uniden Cordless Phone
All three of my Panasonic KX-TGA630S phones are extremely crackly and full of static. What do I do about this?
I already had the base unit and 2 additional handsets, but one month ago, two of the handset do not charge the battery,
I leave the phones charging for 24 hours, and certainly not reached using 5 minutes and dies
I place it in the base load, and loading sign appears, showing up not being charged as well because if I leave it 24 hours Supposed to be loaded.
Jul 02, 2009 | Panasonic KX-TGA630S Cordless Expansion...
Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
joequevedo@charter.net
May 07, 2009 | GE 27992GE5 Cordless Phone
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
"searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Jun 03, 2006 | AT&T 2256 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
251 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
