Question about Mastech Multi-functional bench Frenquency Counter, MS6100
How to measure frequency with the mastech ms6100 frequency counter?
    Master:
  • 683 Answers
Simplest explanation is to connect signal to BNC and select frequency measurement (you may need to play around with it a bit) but it's like any other frequency counter - never used this model but if you know what the frequency you excpect then playn around until you get it
Posted on Oct 30, 2013
Transmitter Frequency alignment
look I'm going to tell you now. If you have no idea where to measure the voltage then you shouldn't be playing with that radio. First ,you need a scope,a frequency counter,a distortion meter,a signal generator,a watt meter,a voltmeter,a sinad meter and patience. If you have none of these then don't mess with it.
Jan 17, 2014 | Galaxy Radios Dx-949 40-channel Ssb Cb...
AC measurement not precise
What AC measurement is not precise (Voltage or Current),
is it a little off or readings are completely off? please give more info
Oct 12, 2013 | Mastech MS8209 Digital Multimeter DMM
How to set mastech multimeter to read small batteries
Set the multimeter to a DC voltage range that includes the voltage you wish to test. Connect the probes with the correct polarity and observe the reading
Mar 16, 2013 | Mastech 19-range Digital Multimeter Dmm...
Temperature probe is reading about 25 degrees F too high. How do I re-calibrate this
these are not very accurate but your reading are out of spec. definitely
check probe and also leave it for some time and then check measurement (5 min or so) maybe it needs longer top stabilize
temperature (K type) uses mV for calculation and therefore cannot be adjusted without adjusting mV DC setting also (if that is possible on this meter)
Mar 23, 2011 | Mastech 8-Function 16-Range AC Clamp Meter...
I have a mastech digiter multimeter It shows only continuty only beep but not shows any AC or DC voltage or current rating after adjust the correct poit of rotary knobe, There is no any hold...
This multimeter measures the voltages this way - the voltage is reduced by the rotary knob to a small value then it's transformed in frequency by an autooscillator - that frequency is measured, In your case the oscillator has failed. It can't be fixed - the oscillator is in the measuring chip. It's dead, buy a new one.
Oct 17, 2010 | Computers & Internet
Out of frecuency magnum s9
If you have a GOOD frequency counter (not the in-line coaxial type), connect the probe to TP3 (It's the top bare lead on R74/Resistor 74)
Adjust L19 for AM measurement of 16.2700 MHz,
L20 for USB Measurement of 16.2725 MHz,
L21 for LSB measurement of 16.2675 MHz.
All 3 of These measurements are + or - 20 Hz
BE SURE TO USE A NON METALIC TOOL! IF YOU DON'T, THE FREQUENCY WILL CHANGE WHEN YOU TAKE THE TOOL AWAY FROM THE TUNING SLUG. ALSO, USE THE CORRECT TOOL!
IF YOU BREK THE TUNING SLUG(s), You'll be in need of someone to replace it/them. In the long run, it may be better to pay someone to re-align the radio rather than risk breaking anything.
Apr 06, 2010 | Magnum S9 Base CB Radio
Mastech Multi-functional bench Frenquency Counter, MS6100 Logo
252 people viewed this question
Top Mastech Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Paul Woodward
Are you a Mastech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
