My bigbeam ssonet 5.1 theatre system keeps turning off and when cold will not even get past volume check?? when it tries to go to input selection in shuts down. there is a switch sound (click) normal sound for off and on. I have removed the power harness to the (looks to be the display and amp??) mainboard,turn it on for 10 minutes then reconnect the harness and it works for about 30 minutes then turns off?? would it be a capacitor or is the system dead??
techman
  • 3130 Answers
SOURCE: chk spkr error message
Your problem is the output IC's The case where you say the speakers buzz tells you theres a short in the audio outputs. If your unit didnt shut off, the speakers would fry and the unit would also smoke. These are solid state devices and are soldered in, and are not concidered user serviceable parts, unless you know how to solder and trouble shoot Stereo systems. This is a job for the pro if you want it fixed. Good Luck
Posted on Jun 22, 2006
techman
  • 3130 Answers
SOURCE: Double clicking sound- no power
The relay contacts are most likely bad in the relay and will most likely happen again. If you know how to solder, take out the relay and look up the numbers on the internet and see what you can find. If not, try to find where the manufactuer is located and call them to see where you can get a new relay. Good Luck
Posted on Mar 28, 2007
  • 113 Answers
SOURCE: Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Posted on Aug 09, 2007
sapperj
  • 70 Answers
SOURCE: Turning Off Irregularily
A voltage converter is not neccessarily the proper piece of equipment to use as most equpment comes with a 120/230 voltage selector. What is probably causing your problem is power frquency. Power in India runs on 50HZ, not the 60Hz we use in the states. This causes a slightly longer peak wave and can cause over heating, therefore shutdown. Check to see if the unit has a 50/60 switch and switch to accordingly.
Back when I was a professional sound engineer and toured abroad, we used a device called an auto-former. These changed the frequency and voltage as needed. Unfortunately the first time I went to England I forgot about this, could not find any pre-built ones and had to spend nearly a week designing and fabricating 8 of them....
Posted on Jan 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Posted on Apr 07, 2008
Second hand zte blade v7 lite and i cant get past the google account verification. I have tried resetting to factory settings but it keeps saying that i need to enter the last owners google account
You need to reset the phone, you are trying to recover someone else's phone.
You can reset your ZTE device's password after power on: input *983*987# in emergency dial-up pad. Select Erase everything. It will restore factory settings and your personal data will be erased.
You can access to emergency dial up even the phone screen lock is on.
Another way to reset your password or gesture lock on your ZTE Blade V7 Lite is
ZTE Blade V7 Lite Andorid recovery menu
Turn off your device. (Sometimes you have to remove the battery and reinsert it before this procedure, if the device has a removable battery.)
Press Volume UP + POWER ON the device.
Keep pressing both key until the Android recovery menu appear.
Now select from the following options.
Highlight wipe data/factory reset with Volume key (power to confirm).
Now highlight Yes -- delete all data and press power to confirm.
After done select reboot system now.
All data will be deleted!
Jun 22, 2017 | Google Computers & Internet
Interior lights
This is both a courtesy and safety issue on many high end vehicles. The light from the interior lights can cast enough light to get to front door and possibly show dangers in your path. And after first getting into you car and starting it, you can check the back seat for any unwanted hitchhikers. As for the 10 minute timer, I don't know if this can be adjusted. A Chiltons/Haynes repair manual for you car may have that answer, or, the Buick dealership shop foreman. Best of luck.
May 31, 2015 | 1998 Buick Park Avenue
I can not get my RCA Blu Ray home theater to play what comes through on regular tv. It plays a dvd and will also play when using netflix from my ps3. I do not have any sort of cable box. My tv is a Sa
Gotta find an audio output from the TV and run it to aux input on the home theatre, select the aux function and it should work, if your tv has no audio out see if it has a headphone jack you can use as an audio out, can get a cable with 3.5mm headphone jack one 1 end and rCA red/white on the other, becareful when doin this as the audio output level froma headphone jack maybe controlled by the tV's volume itself. keep tV volume low and use the home theatre volume if your doing it that way
Nov 24, 2013 | RCA Blu-ray Home Theater With Vudu,...
Volume control stuck
Hi Jenny,normally to resolve the problem you are experiencing,I strip the volume control and service it.You need to take it to a technician to have it repaired.Thanks Ravi
Nov 21, 2011 | Panasonic Home Theater System System
My tabled blocked and I can't do anythink, not even turn it off.
Hi Daniela_p446
The best solution I can offer you is too firstly hold the power down till it eventually switches off (if i refuses try to press the volume + and power buttons).
Then once off restart it by holding down the volume + button down button whilst pressing the power button, until a white screen appears (the system recovery screen). It generally takes about 5-45 seconds.
Use the volume buttons to then scroll up and down and the power button to select and option; select format system then reformat device.
Hopefully this will help and fix your Archos.
If it doesn't I suggest you return it to the manufacturer/seller (depending on when you purchased it) as it maybe a hardware failure if the system refuses to accept inputs.
Mar 03, 2011 | Archos 70 Internet Tablet
How do I listen to my Sharp LC-32L400M through my home theatre system?
Depending on the home theatre system and the tv. Your TV will have an audio out of some sort ie: Headphone jack, Digital Audio Out, Or something along those lines. And as far as the home theater system what kind of inputs do you have, Aux with a headphone jack, or digital audio in something along those lines. You have to be able to match them up. For example my TV has a headphone out, and my Surround has RCA cable input jacks for the AUX. I ran a headphone jack to 2 RCA white and red plugs. Once you have to correct connections made, you may have to adjust your tv volume mine is at about a quarter the way up, But make sure when you plug it all in that you select the correct input on your Theatre system. Hope this clears some issues up for you. Cheers
Feb 06, 2011 | Televison & Video
My bass powered subwoofer on JVC system doesn't turn on
You need to check the signal. If there is not signal present or the volume is low the sub will not turn on and goes in to sleep mode.
-david
Nov 09, 2010 | JVC THC3 800 Watt 5-Disc DVD Home Theatre...
LG LHB953 Theatre system volume control with comcast dvr 3
Try the help menu in the comcast remote. I believe you have to program it again for the LG to work the sound.
Jan 01, 2010 | Televison & Video
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
Need some sound to my home theatre system
Just 2feb827.jpgrun red and white composite audio cables from the audio out ports above the AVin1 ports on the back of the tv to one of the audio input ports on the home theater system, remember which input port you connected it to and when you want to watch tv with the home theater sound just switch to that input on the home theater system.
Feb 04, 2009 | LG 42LG50 42 in. LCD HDTV
 Grubhead
Grubhead
