Question about Kenmore 72982 Gas Dryer
Dryer was flooded when we had a sewer back up.
Have a Kenmore model #110.76712693 76712 that was submerged under 18 inches of water and water was also reaching the top of the dryer from a sewer back up. The sewer access is right by the washer & dryer and was spraying on top of the dryer. It took a couple of days to start working, but eventually did start heating up. The problem is that it has never worked the same and takes on average 20 minutes longer to dry the clothes and has a strange smell as well. The Kenmore 80 series washer was also under water and stops unexpectedly mid cycle. Specifically when filling. It will fill for hours. What are your thoughts to long term damage and if they should just be replaced rather than repairing.
  • 56 Answers
Water can damage alot of the parts on the washer and dryer the motor would have been completly under water on both units and the control on the dryer would have gottin wet as a repair man anything can be fixed but to what cost
Posted on Jun 03, 2010
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Kenmore 90 series washer we want to put it in the basement- How high will it pump the water(no drainpipes in basement) and can I plumb it directly into our 2 inch gray water pipe or do I need to pump...
no higher than the manufacture drain hose can reach ...no donot plum directly to pipe !!! yes if must into a utility making sure pump hose goosneck and end of drain hose never gets submerged under water cause water to siphon back into washer....
Jan 28, 2011 | Washing Machines
Speed Queen Commercial Dryer model EE111OL (electric) got wet in recent flood, still spins but not getting heat. Is it the thermostat, sensor or igniter that is bad and needs replacement?
If this dryer was submerged any component that was in water needs to be replaced. NOT cleaned and reused. there could be water in he burner and any electrical or mechanical component that was in water will soon fail if it hasn't already. This is a safety issue. Please have this repaired as if your life depends on it as it may.
Eric
Jul 30, 2010 | Speed Queen AES28AWF Electric Dryer
I have a kenmore elite model 110-76942501 Does not start after flooding in basement
almost every dryer i've seen that was under water needed the motor replaced,check with a meter to see if power is going to motor,if it is then you know it's the motor,and i'd bet 95 percent of the time it will be the motor
Jul 27, 2010 | Kenmore Dryers
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Dryer won't run.
First, there is an excellent chance you have some kind of flood damage insurance.  It may pay for part of the repair.  You did not tell us what is not working but I'll guess it is the motor.  On many models, there is a switch on the motor which will not allow the elements to heat unless the motor is powered and running.
Dec 19, 2008 | Kenmore 63942 Dryer
Dryer not taking out moisture
your venting from the dryer probably also submerged in the "flood", try taking that apart and make sure its not clogged, sounds as if the dryer is not able to release the heat that its producing
Jul 25, 2008 | Dryers
Won't start after flood
First I would remove motor and put it in an oven for a few hrs at min temperature like 200 degrees then I would remove motor centricical switch and push in the actuator tab a few times, then put it back in. Use a cheater cord plugged into pins 4&5 and see if the motor runs, it should.
Apr 17, 2007 | Kenmore 74972 Gas Dryer
Kenmore 72982 Gas Dryer Logo
127 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
