Question about Mantis 2-Cycle Tiller
Is there a rebuild manual for the carburator
I have a rebuilding kit for the carburator but don't have any instructions
  • 391 Answers
The little Walbro carburetors or those like it are difficult to rebuild successfully but as to your question, you should repace the parts as you encounter them in the carburetor.
Posted on Jun 02, 2010
22r carburator diagram
There is said diagram in every rebuild kit for the carburetor.Assuming you're going to rebuild it,that is.And if you're having problems with it,rebuild it.Any NAPA store will get the kit for you.
Apr 13, 2014 | Toyota Pickup Cars & Trucks
How do you rebuild carbator
Hi liquidjay
You did not say what the rebuild kit was for, just the numbers don' t help.
I will send you to a webpage that is a little more than you need, but it is also how to rebuild a carburator.
Bud
Apr 24, 2013 | Garden
Water in fuel will not start and when it stars it will not idle, how to rebuilt the carburator
If you buy a rebuild kit it will come with an instruction sheet. If you do rebuild your carb be sure and check the floats for holes as well. If there is water in the fuel - try totally emtying the tank and add a little methyl hydrate. It mixes with water and fuel and may clear your tank of any remaining H2O. Cheaper than a rebuild if it works. Let me know. Thanks.
Feb 06, 2011 | Miller Welding Tools
I need a 22R aisan carburator diagram so I can rebuild my carburator.
purchase the carburetor rebuild kit for your carburetor and it should have instructions in the box to aid you in rebuilding it . Remember , to do it correctly you must get an acid wash tank to submerge the entire carburetor body into before you install the new parts . And be sure to clean it thoroughly after you remove it from the acid dip tank .
Nov 18, 2010 | 1986 Toyota Pickup 4WD
I have a 1986 Chevy G20 V8 5 liter van. the shop says it needs a new carburator but since it's half manual and half electronic it will be $1500. plus instalation. gotta be another way. I got it for the...
rebuild carb yourself, unless housing is cracked. look online for rebuild kit. They usually come with instructions. If not, just take good notes while taking it apart so you get it back together right. Did they say what was wrong with it? What were symptoms?
Sep 04, 2010 | 1986 Chevrolet G20
Carb is leaking it looks like accelerator pump. truck still runs not sure if there is a gasket i could replace.
Hi!!
There is a carburator rebuild kit that you can get at the AutoParts store for your vehicle. Runs about $25 and it has a diagram and step by step instruccions on how to rebuild the carburator yourself. If you don't feel comfrortable doing it, take it to a carburator shop for rebuilding. It is cheaper if you take the carb. by itself. Before removing carb. take a few pictures of the hoses and linkage n mark each hose and electrical connection removed, this will make your life a lot easier when you install it back.
Don't forget to rate this answer, Good Luck.
Apr 27, 2010 | 1986 Dodge Ram 50
Solex h32/34 pdsi-3
Go to the parts store and order a rebuild kit,it will have a break down of the carburetor in it,and the adjustments
Apr 21, 2010 | 1978 Chevrolet Chevette
Would like a print and some info on rebuilding a chevy tbi carburator. This is for a 1989 chevrolet fuel injection TBI carburator. Thanks, Jerry
Here is a real good page on TBI
http://chevythunder.com/gm_throttle_body_injection_pg_1.htm
When you ask for the kit at the part store some list it as a carburator rebuild kit and some list it as a Throttle Body rebuild kit. Not much to rebuild, Clean it put in new gaskets and o-rings. There is two different kits one comes with a new fuel pressure regulator and one does not. Best to check fuel pressure and fuel filter prior to purchasing the kit. Fuel injectors should be tested and cleaned by a shop. I found a carquest auto parts that had the machines to do it and cost me $40 for 2 injectors.
Jan 09, 2010 | 1989 Chevrolet Suburban
Mantis 2-Cycle Tiller Logo
606 people viewed this question
Top Mantis Garden Experts
Mike Squire
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Mantis Garden Expert? Answer questions, earn points and help others
