Question about Estate TEDS740JQ Electric Dryer
The basement flooded and the dryer is making only a humming sound
  • 56 Answers
I would try to spin the tub sounds like the motor might have locked up
Posted on Jun 03, 2010
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Lg dryer basement flooded, water up about 8 inches on the dryer. in water about 8 hours, Dried it out turned it on panel worked drum turned but no heat then the drum stopped turning. just hums now? Is it...
there is a chance that the motor contacts have been corroded,depends on the age of the machine.and if there is a control board in the lower half of the dryer it could be as much as three hundred to fix it especially if you have a service tech come out and look at it if the unit is not under warranty.
Nov 21, 2010 | Dryers
I have a kenmore front loader dryer. My basement recently had a flood and the bottom of the dryer was wet. When i tried to start it, it hums but will not run. What is the problem?
the motor is cooked,i live in the boston area and we had some bad floods a few months ago,all i did for two weeks was change out dryer motors,you can try to spin the drum and hold in the door switch and have someone else hold in the start button to see if it will start but you have to change out the dryer or get a new one if it's in rough shape
Aug 05, 2010 | Kenmore 73952 Gas Dryer
I have a Kenmore 600 electric dryer. The basement flooded and the dryer was in approximately 6 inches of water. I've removed all the water from the cabinet and let it sit for 2 days to completely dry out....
Sorry to say but water ruined the motor. You can test it again by pushing the start button and at the same time spin the motor. If the motor starts that will tell you the start windings in the motor are bad. The motor would have to be replaced.
Mar 20, 2010 | Kenmore 63942 Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Whirpool Mod WGD5300SQ0
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Jul 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Estate TEDS740JQ Electric Dryer Logo
51 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
