Question about Mitsubishi WS-65809 65" Rear Projection Television
Red color smears to the right after its been on for awhile, what could it be?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
Smearing on the right side of the page
See the user guide on page 191 and following to clean the paper path.
Nov 16, 2011 | HP Laserjet CM2320nf All-In-One Color...
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
Yellow not installed
Are you using a factory new HP cartridge? If so, contact HP and request a warranty replacement of the toner cartridge.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
Flickering picture and color smear
Trash it Toshiba T.V. and laptops have a flickering problem with is caused by a failty power supply
May 27, 2009 | Toshiba 52HM95 52" HDTV Projection...
Addresses on envelopes have begun smearing
clean all the feed rollers with a window cleaner, shoukld be fine then
canon tech
Mar 31, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Horizontal Lines and smeared color
No its not a cheap repair Renee, please don't invest your hard earned money into an old 32". If you can buy a newer LCD or Plasma set. LCD's are cheaper and have the smaller sizes that you may want.
Apr 08, 2008 | Televison & Video
Smearing of colors
I have a red tint on the left side of my display at all times. also red smear after any white boxes in display. Has anyone else had this problem?
Feb 19, 2008 | Planar WS231 23.1 in. Flat Panel LCD...
Bad picture
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Nov 29, 2007 | Toshiba 55H70 55" Rear Projection...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
