Question about Hayward H400FDN Low NOx Natural Gas Pool or Spa Heater
About to purchase and install a Hayward H400FDP Propane 400,000 BTU Univeral Low-Nox Pool Heater. Manual clearly states that a 1" PIPE is required for runs less than 50 feet. Tubing is not listed as an option for this heater although it is for lower BTU heaters. My run is under 30 feet. The Propane company that is installing the propane tanks is telling me that their installation will use 7/8" tubing and that it will be sufficient. Hayward's manual clearly states that they will not be responsible for issues caused by insufficient fuel being delivered to their heaters. Should I let the Propane company install the 7/8" tubing and hope for the best or try to find a new company?
  • 64 Answers
I would definately go with the manual. I am a warranty station for hayward, and if there is a low gas pressure problem and the meter or line is not sized properly, we will make you remedy that before we can proceed further. Of course that is if there is a gas pressure problem. For me, in this case, bigger is always better. I always suggest 1.25" gas lines. But, i also work in an area where all the supplies are natural gas. Poly Pipe or yellow pipe with a tracer wire is standard material in the area I am in. I do believe when you look at the manual, it will say MINIMUM SIZE. In the end, i would insist at least having the minimum recommended gas line installed. Pool heaters use ALOT of gas. HTH
Posted on Jun 02, 2010
I have Hayward H400IDL2 heater I recently had #1 and #2 1.5 amp fuses blow. I replaced them and then the #4 2.5 amp blew so I replaced it. When I press the mode button to spa the heater blower comes
Good Day, missed your post for a few days. #1 & #2 fuses are on the high voltage side. This could mean a problem with incoming voltage or a bad fuse or main circuit board. Call our tech line at 908 355-7996. I have attached a link to the manual. http://www.hayward-pool.com/pdf/manuals/H-seriesLowNOx-H250IDL2-H350IDL2-H400IDL2.pdf
Aug 24, 2014 | Hayward H400idl2 400,000 Btu Low Nox...
Heater exhaust fan kicks on when rpm on vspeed pump drops below 1950
your pump speed is too low to keep the heater going, you need to ramp up the speed of your pump, and/or disassemble and clean your filter.
Feb 23, 2014 | Hayward H400idl2 400,000 Btu Low Nox...
Need a presure switch for a haywwod h400fdp propane gas pool heater also a price
The part number is FDXLWPS1930 and should cost you $20-$25 if bought locally although it could be up as high as $40.
John
Mar 03, 2011 | Hayward H Series Pool & Spa Heater 400k...
I am replacing my old 400,000 btu natural gas pool heater with a Hayward 250FDN, which will be adequate because I plan only to heat the spa, not the whole in-ground pool. My question is how much of the...
This should be an easy installation. PVC is easy to install as stated above. Electrical, just follow the directions in the installation manual. As far as the gas line goes, you CAN use a flex line in place of the black gas piping for the 2 feet BUT make sure it is adequate for the amouont of BTUs you will be running. ALL flex-gas pipe has a rating on the side of that will indicate the maximum amount of BTUs that can run through the pipe. The highest rated flex Ive seen @ 2 feet is for 297,000 BTUs. You should be fine at 250000. Chances are the local hardware store will not have this good flex pipe though. You will have to goto a local HVAC store to aquire it.
Feb 07, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
My plumber needs manual for Hayward #H400 FDP
The P at the end stans for propane...the manual found here is for the H400FD series natural gas or propane.
John
May 31, 2010 | Hayward 400FDP Universal Series Low Nox...
Hayward H400FDN Low NOx Natural Gas Pool or Spa Heater Logo
226 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
