Question about Dryers
Clothes not drying completely when the dryer stops
    President:
  • 512 Answers
Vent needs to be cleaned from inside of dryer to where exits out of the house. Excess lint stuck to walls of vent pipe hold in moisture and will not let clothes dry.
Posted on Jun 04, 2010
Maytag performance dryer not drying clothes. We have checked the lint trap and the b ack of the dryer any ideas?
Check ventilation going out of house and inside dryer itself. If either is stopped up, clothes won't dry properly. If venting and dryer is completely clear, things I would check would be proper voltage going to dryer, heating element, thermal cutoff and high limit thermostat, operating thermostat, timer, and motor in that order.
Sep 02, 2017 | Maytag Dryers
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer does not dry clothes completely
If your machine is taking that long to dry. You either have a clogged vent to the outside or your gas valve coils are bad. You can check to see if it is your vent by disconnecting it for one cycle. If the unit drys in time then clean your vent. Click Here to see what a clogged vent can do. Click here to see gas valve coils.
Apr 01, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
MY DRYER WILL NOT DRY THE CLOTHES WHEN I USE THE REGULAR CYCLES. I HAVE TO DRY THE CLOTHES ON TIMED DRY FOR 90 MINUTES AND THEN SOMETIMES THEY ARE NOT COMPLETELY DRY. THE DRYER IS DEFINATELY GETTING HOT,...
Your vent system is more than likely stopped up..You may have to pull the dryer out and clean the flexible hose that connects the vent to the outdoors
Apr 12, 2011 | Dryers
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 05, 2009 | Dryers
Dryer stopped before clothes were dry and now it will not start again
possible bad thermal fuse remove back look for small white object on left side just above blower on side if lint screen housing with continuity checker ck to make sure there a closed connection through fuse
Jun 04, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
