Question about Dynex 32 in. LCD Flat-Panel HDTV
What settings do I make to connect my laptop to my DYNEX Tv
Connected VGA to Laptop
All I get is a blue screen
  • 91 Answers
Please select the PC input on the dynex remote using the input key,then try shutting down the computer and restarting it .
Posted on Jun 02, 2010
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
I have connected my hp Pavilion dv6 to my panasonic p46v20z but no picture shows on tv. Is my pc not compatible?
Usually there is a key on the keyboard that must be pressed with the function key to alternate the video outputs. Usually it is Function F7 or F8. This key set must be pressed more than once to get the preferred setting. Each time it is pressed you will get one of the following. Out VGA, Out VGA and Monitor Screen, and only Monitor Screen.
Monitor Screen being the laptops display screen. Out VGA being the rear port on the laptop.
This is usually the reason for the issue you are having.
Jan 29, 2013 | Computers & Internet
I connect my Toshiba Satellite L505D-S5983 to my Dynex flat screen tv and if so what cable do I need? Thanks
In order to connect your laptop to your tv's display you will need a VGA to component or composite cable. The VGA part is connected to your laptop on the left side next to the network jack and then the composite or component part to the corresponding inputs on your tv. Here's a site that sells them just to give you an idea of what you will need. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023503&p_id=2170&seq=1&format=2
You should be able to find a similar cable at your local electronics store.
Jul 15, 2011 | Lifetime Toshiba Satellite L505D-S5983...
What is MAxmedia tv for?
its a VGA to s-video/composite(rca) converter. it allow you to connect a computer to a tv with compatible inputs. Example would be to connect your laptop to a tv to show videos or pictures at a family gathering. you connect a VGA cable to the VGA output on the laptop(usually blue) connected to the MaxMedia TV II Plus, then from there you could connect a set of rca to the tv and view whatever the laptop sees on the tv screen with audio.
another example with a diagram
hope this helps
Apr 18, 2011 | Umax MaxMedia TV II Plus (MTMD-83611)
Compag laptop connected to LG HD TV. TV screen just show blues and greens, no reds. What do I need to do
To troubleshoot this, you must first start with the obvious. Check your cable connections/try replacing the cable. If this does not work you should then check the color settings in the tv. If that still does not work you can try connecting your laptop to a different monitor/tv. If the color shows up with the same problem, you know the issue is contained within the computer itself. Possibly bad VGA/HDMI Port or color management settings.
Nov 18, 2010 | Compaq Computers & Internet
How do i connect my toshiba tecra s1 laptop to my tv.
First you will need a double female ended VGA cable, plug into the blue triangular socket on the lap top and to the same socket on the back of the tv, as long as the tv has a VGA socket you will be ok.
Make sure that the signal source on the tv is set to pc, on the pc right click on the screen to enter the display properties, goto the settings tab, in the settings window at the bottem you will see a slider for the resolution, change the resolution to 800 by 600, on the right you will see the bit setting change this setting to 16bit or 24bit and click apply click ok to keep this setting, restart the laptop, as long as everything is connected correctly when the laptop boots you should see the windows screen on the tv. good luck and i hope this helps.
Oct 25, 2010 | Toshiba Tecra S1 Laptop Notebook
Laptop to TV connection problem
When your laptop boots up, Windows treats the second monitor (your TV) as a mirror of the primary monitor (your laptop screen). When Windows loads up and finishes initializing the more advanced features, it goes back to it's default setting of a single primary screen, and the secondary screen is in standby, waiting for you to do something with it. The fastest way to get the TV working would be to find the Function key on your keyboard (normally a purple-ish blue key labeled Fn) and the monitor switch key. The video switch key is normally in the Function key row (F1, F2, F3, etc...) and has the picture of a rectangle or TV-looking shape. Hold the Fn key down and then press the video-switch key once and see what happens. Lenovo laptops normally bring up a little on-screen program that allows you to pick which configuration you want. Good luck!
Jan 14, 2010 | IBM Computers & Internet
19'' Dynex TV does not come up as a Computer Monitor.
Follow these steps on the remote :
Press Input,
scroll down and select VGA.
Nov 17, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
621 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
