Question about Ryobi Cultivator
I have a Ryobi gas cultivator. Model RY60511B. The starting rope won't retract, and is pulled all the way out. When I took the housing apart and manually wound the rope back inside, I tried to start it again by pulling it out, and it again didn't retract.
5 Suggested Answers
  • 1632 Answers
SOURCE: unable to start Ryobi 410r cultivator
After starting close the choke , push the lever back in
Vitally
Posted on Jun 02, 2009
  • 112 Answers
SOURCE: ryobi 410r cultivator needs intital carb adjust
screw in lightly till seated then back out 1 turn each. low is for idling and turn in or out for best idle then run full throttle and do the same for it, get highest rpm then turn out 1/8 more on the high jet.
Posted on Jul 15, 2009
  • 144 Answers
SOURCE: My Ryobi cultivator starts and runs but stalls as
Hi quinn4776, I will try to help you with this problem. This sounds like a problem with the governor or carb adjust. Try this first, adjust the high speed mixture needle that is located at the bottom of the carburetor float bowl by turning it in 1/8 turn increments counterclockwise (4 to 6 times). After each adjustment run it and see if there is any difference. If no difference return the screw to original position. (Before doing any adjustments remember the position you start from). Now do the same with the low or idle mixture needle located on the side of carb, Try the tiller after every adjust. If this does not work return screw to original position. It could be the governor. The governor is like the gas pedal on you car, as you put a load like starting to go up a hill need to press on the gas pedal, well on your tiller the governor does this automatically for you. When you look at the carb, right on the top you should see 2 linkages that attach at two different places. One link should have a spring attached to it. Check to see if it is broken, if it is then it has to be replaced. If it looks like it's unhooked, try to locate where it goes and re-attach. If everything is OK when you check it out, then it might be an adjustment that is needed. I will not try to explain how to adjust it here it is too difficult to put into words. I hope this helps even a little bit. All the best and good luck.
Posted on Feb 09, 2011
How do you replace the pull start rope?
Remove retaning bolts on the housing make sure all the old rope is ggonerewind the housing useing a screwdriver to hold it in place thread the new rope through the housing release screwdriver and reattach to motor.
Apr 18, 2016 | Yard Machines 121R 31cc 2-Cycle Gas...
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull cord on briggs & strtton wont retract back
If you don't know how you will need a manual, it is kind of tricky.
Remove the rope. Feed the spring from the outside of the housing and connect to the recoil housing. Turn the wheel using a 3/4 " rachet extension and the spring will feed ito the housing until the end of the spring connects to the ouside of the housing. Keep turning until the spring is tight, back off about 1/2 turn and feed the rope from the outside, be carful here, if the extecsion comes out the spring will uncoil and you get to start off all over again.
Apr 16, 2013 | Briggs & Stratton Garden
Ryobi string trimmer RY34420 has a non retracting pull cord. How do I fix it?
The starter assembly is between the motor and boom so you have to remove the boom from the motor housing. Usually one nut & bolt at the nose of the starter housing. There may be another lock bolt. You shouldn't have to remove the throttle cable and leads but it depends on how tight the factory installed them. Remove the starter housing. If you're real lucky all you have to do is pull some starter rope up past the pulley and wind the pulley in the direction the rope pulls back into the housing. You have to pull the rope around the pulley as you wind it. If the spring catches and builds tension you're good, wind it four or five times or enough to fully pull the rope back in. If the spring doesn't catch or releases every two or three turns it has to be replaced. You may have to replace the spring and container (PN638033001) and/or the easy start assembly (PN310022001).
Aug 31, 2010 | Ryobi Garden
I have a troybilt tb-144 4 stroke mini tiller. The pull cord, pulls and retracts as it should, but is not engaging the engine when pulled...
remove the top cover. look inside while pulling rope briskly, you should see two dogs fly out and retract when the cord reaches its end. if not, check for dirt in the system and clean out. if no dogs, you will have to remove the system from the housing, be careful of the spring. check for any broken drive parts. also check flywheel cup for damage where the dogs come into contact with it.
Apr 15, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
How to place back the spring and a new rope
First you take the unit apart at the engine/shaft junction. Take a #15 Torx screwdriver into the end of the clutch and remover the driver. Once the clutch is clear, you have to remove it. Some people put a bolt of the same thread size as the spark plug into the plug hole far enough to touch the piston. When that is done, take a piece of hardwood and spin the clutch off. Use a hammer if you need to. Next, pull apart the engine from the casing. You now have the rope and spring at the end. If the spring has not come out of the metal ring, LEAVE IT ALONE! Replace the rope and leave the rope off the spool. Now carefully place the spool onto the spring and wind the spring tight while holding the rope in the cutout provided at the edge of the spool. Once you have the spring wound up, CAREFULLY allow the rope to retract. Attach the spool and re-assemble the unit in the reverse order you took it apart. Hope this is enough info. Please use caution when working with the spring. Good luck...Lee
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The Pull cord was jamming. I took it apart and
the rope and spring both have thier respective place in the housing for thier mountings they can be rewound by hand and reassembled with success,hint oppisite end of spring has a anchor point on the housing while one end is secured by a cup like screw mounting,to create the retracting force for retrival of the pull start rope its tricky if haven't done it before but you learn by trying Good luck Steve
Oct 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pull rope will not retract
You may need a new spring.
Mar 25, 2009 | Ryobi Garden
Ryobi Cultivator Logo
292 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
