Question about LG Washing Machines
Tub fills up when washer off - LG Washing Machines
  • 343 Answers
If the washer fills while switched off at the wall, then the water inlet valve is faulty. Inlet valves are made to only work when power is supplied, and to shut off when the power is stopped. Detect which temperature by using the tap(s) and replace the inlet valve....Good luck....Nomess
Posted on Jun 03, 2010
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Washer filled and will not drain if I reset the fill capacity knob it will fill but not drain.
This washer has a belt. The belt drives the pump on this washer. The motor turns in both directions. iIn one direction the washer tub is locked and the tranny agitates. The water pumps out and the tub spins in the other direction. If that pump is locked up or the hose from tub to pump is blocked then it wont pump the water out. Lay the drain hose down towards a bucket and see if any water comes out. If not you got blockage. Once you drain it out tip is back and remove the belt (no tools needed) turn the pump both directions and look for signs of a failed pump. Manual and more
Jun 30, 2011 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Leaks while tub is filling.
could be any number of things: water inlet to tub leaking and running down outside tub,tub seal on top of transmission,pump leaking,bad hose washer remove top and front cover,then plug-in and let it start to fill you should be able to see your leak easier that way be careful when plugged-in
Aug 02, 2009 | Amana NAV2335A Top Load Washer
When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Jul 16, 2009 | Haier XQBM22-C Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
