I need to download a program from Meritline for CD and DVD Disc Labels. I have the blank labels.
  • 3,083 Answers
Here are some free downloads for various labels:
http://www.meritline.com/mercddvdavla---c-8218.aspx
Scroll down to find them. You will see a column for Avery and another column for Meritline. These are the templates for the labels for Microsoft Word, and it looks like it is what you need. If this doesn't work, you might have to purchase another kit with the software. Here's one site that offers a package. http://www.onlinelabels.com/Software/ezLabel.htm
Good luck, and hope this helps!
Posted on Jun 02, 2010
I want to print a label onto a DVD I am burning using my HP6180 All-in-one printer. Does anyone know how i can do it?
Your printer is not printing straight to a DVD, so you will have to buy self adhesive labels, print on them and then stick the label on the disc. Now, it all depends on what software you have available. Your might have software included with the Photosmart printer for CD/DVD label printing, check your installer CD that came with the printer. If you don't, and use Nero for burning DVDs, you may notice it has a label printing software that comes with it. You will need this type of software in order to print a label. If you don't have Nero, or any other label printing software you can try using some of the free ones that are out there, like Disketch 2.11. There's also a lot of free to try label printing software, like Acoustica CD DVD Label Maker which you can use for 15 days for free. If you have Photoshop and you're good using it, then this is another option to consider (you can download templates online).
Using a label printing software is pretty easy, most of them will have templates that you can open and just edit, or you can start with a blank design and add text and pictures to it. When you are finnished put the special label paper in the printer and click print. If you have special DVD labels make sure you specify that in the printing preferences before you print.
Dec 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip ~1.34KB)
2.) Extract the BootSector file (boot.ima) from bootfiles-from-tacktech-website.zip
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Regards
Pcs365.8
Jun 01, 2010 | Microsoft Windows XP Home Edition
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Roxio Label Creator won't print labels (blank with scissors)
Go to the label creator in your Roxio 6, Click on EDIT, then click on PREFERENCES, go to the DISC tab and unclick the "Print Disc cut Lines" and the "Print Disc outline" boxes. This should fix your problem.
Sep 13, 2008 | Roxio Easy CD & DVD Creator 6...
Can I print a cd on my canon mp510 printer?
You need to download a CD cover creator software. If you also want to print your own CD label stickers (round ones for the disk) you will need also to buy CD avery templates.
Here is the software:
Download Super CD Cover Maker v2.0.0
Cd Cover Label Software Freeware
CD Cover Designer 2.5 {freeware} at Damn Printer
Free CD/DVD Covers Software Downloads
Cd covers Free Download
Easy CD and DVD Cover Creator and Label Maker.
Here instead you can buy cd labels:
Avery Labels, buy Avery office products, Avery CD Labels
Sep 06, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Label is printing but it is dispensing 4 extra blank labels.
If you are using Avery labels or an euquivalent. Go to avery.com and download and install the labelmaking program. If you are using Microsoft Office software it should integrate into it as well.
Select the correct form from the label making program and the blank labels should go away if there is something to print on them.
Jul 21, 2008 | Dymo Office Equipment & Supplies
Cd label
I finally figured it out. The default DISC LABEL got set to HP TATTO. It should be PRINTABLE CD/DVD STANDARD. The HP Tatto uses the photo paper tray so the printer wants you to close the DVD tray
May 08, 2008 | HP Photosmart C5280 Printer
CD/DVD Labels
To answer your question accurately, we'll need the manufacturer and the style or product number of the labels you purchased. If they're Avery, or other popular brand, you should be able to use Microsoft Word or Microsoft Works templates which are provided online for free. At the very least, you should be able to (using printout on blank paper as a template) maneuver the label design to fit within the area that your labels occupy and then when you print onto the labels you'll see even more accurately how to adjust future printouts (if necessary). I always do this, even when I use the Avery DesignPro software (free version from Avery). It helps me to keep from having to throw away misprints when the print runs off the edges.
Hope this will FixYa!!!
Mar 30, 2008 | Ulead DVD MovieFactory for PC
Lightscribe
You can get colored blank discs, but the Lightscribe only "prints" in shades of black. You will need to get Lightscribe compatible discs, which are just like "normal" cd's / dvd's with the exception of having a special coating on the one side.
You can visit Lightscribe's website for complete tutorials.
www.lightscribe.com
Feb 25, 2008 | Computers & Internet
Lightscribe CD Burner
try and reinstall the sonic program if you have it. it sounds like the computer did not have the sonic software on it when you bought it, so it would have been removed when you restored your computer.
Nov 18, 2007 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
