Question about Ps P&s Double Pole Lock Switch 20a 120/277v 20ac2-l
I have 5 PS Double Pole Single Through Toggle Switches 20AMP 120/277VAC. The swithc levers are lighted. The only problem I have had is the burn out of the neon light in the switch lever - light ON when power is ON (only). What remidy do you have?
    Scholar:
  • 130 Answers
There are two type lighted switches. One is called the pilot light switch and the other is called an indicator lighted switch. One application for the pilot light would be to tell you if you have the basement lights on. It would be located upstairs in the house near the closed basement door. This way you would know if someone is doing the laundry downstairs without opening the door because the neon would illuminate when the lights were on. The indicator switch would be used in for areas that you want someone to find the switch in the dark. like a elderly persons room. (it is also good as a night light). I wouldn't worry too much about it burning out, Neon can last over 15 yrs !
Posted on Jun 06, 2010
Why does some automotive toggle switches have just two prong for power and some have three for power and ground. Is the ground necessary when what you're wiring is already grounded?
The switch with two prongs is a single-pole, single-throw switch; it is either on or off. The switch with three prongs is likely a single-pole, double-throw switch. That is, it controls two circuits but only one can be on at a time. For instance, it could control a two-speed fan with one position being low and the other being high. The "ground" you speak of is the common terminal and may or may not be connected to ground. You can find more information by searching for SPDT and SPST switches on Google.
Dec 29, 2016 | Dryers
How do I wire double elrctrical switches?
i assume both switches are single pole? How to wire depends on what wires you have in the box (i.e. the circuit they are in).
Aug 10, 2014 | Leviton White Double Wall Light Switch...
I need to buy a SPDT low voltage momentary contact toggle switch.
You want toggle switch that mimics operation of pushbutton, except you want SPDT.
For example doorbell button is a momentary SPST
http://www.mrsupply.com/leviton-5657-2w-double-throw-ctr-off-momentary-contact-switch.html
http://www.csnlighting.com/Legrand-TM811DTMOBK-LEE1616.html
For others finding this thread: Many people want double throw switch for 240V, thinking they have to turn off both hot legs of 240V circuit.
240v can be turned off by cutting power to one hot leg.
http://waterheatertimer.org/B220C.html
Aug 01, 2011 | Lutron Ivory - Ariadni Dimmer - Magnetic...
I have a single pole switch with single receptacle. It is in a double box, I want to change this to a single pole switch with a double receptacle beside it. How?
Unless I misunderstand you, you just need to get a single switch, and a duplex outlet with a matching plate. Your hardest part will be to decide the color of the devices and plate (rectangular, double-D holes, etc. I'd suggest, that for "preserving domestic tranquility" you hire you mate (if any) as consultant on these matters.
(Wire it as it is now; that is if the switch controls the outlet the wiring should still be easy to follow.
DO turn off the power first!)
Feb 14, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
Pushomatic Double Pole, 20amp problem. When I
Most two-pole breakers have a small plastic bar that connects the two switches allowing them to be synchronized and used as a single breaker. However there are some two pole breakers that are intended to be used as two separate breaker and lack the need for the bar that synchronizes them, this is because they are not being used to power a single circuit or item, but separate circuits, or items. so no the breaker is not bad, and yes can be used to power single circuits or items.
Jan 17, 2010 | Connecticut Electric & Switch Thqp115...
How to do you wire 2 separate exhaust fans to a double single pole switch with a 20amp breaker problem
Your statement is a bit off the wall
Do you have two single pole switches or two double pole switches
You would normally provide a Live, Neutral and Earth to each fan via a switched , double pole, fused spur box .(You run a cable from the spur to a junction box) , you then run a LNE to each of the fans (using plastic trunking or conduit if the cables cannot be sunk into a wall).
Inside the junction box you remove the Live supply cable from the connector which should now be carrying three cables leaving the two cables running to the fans.
Put the Live wire into the spare connector inside the junction box
Get a twin and earth cable with the two wires marked up as Lives (Brown or Red in the UK, or whatever your wiring colour code dictates in your country) take those to a single pole switch which is convenient to you and wire them in
Back at the junction box put one of those wire into the connector where the two Supply wires for the fans are and tighten them up
Put the second wire from the On/Off switch to the Spare connector in the junction box which is holding the Live Supply
You then have a fused supply with a switch to break the circuit
If you do not need a switch then ignore the second part and just rely on using the switched fused spur to control them.
You can use a single pole switch but it is safer to stick with the double pole version
The breaker will be out of the loop as that will provide the power and you should not be fitting wires to it
Jan 02, 2010 | Broan-NuTone Nutone Utility Exhaust Fan...
Hooking up a combination switch with outlet and another switch
ok, i think what you mean is a 3-way switch- meaning two different switches that control one light and a single (pole) switch that only controls one light. you can't do that with the above switch. You need a combination 3-way and single pole switch.
Sep 30, 2009 | Leviton COMBINATION SINGLE POLE TOGGLE...
I have a 20amp 120volt switch. It has 2 screw at one end both marked line. 2 screws at the other end marked load. how do I wire? 10g black, white, ground in. 10g black, white, ground out. I want simple on...
The switch you have is either a 4 way switch, or a 2 pole switch. it is more expensive than a single pole switch. If it says on/off on the toggle it is a 2 pole. Simple solution is to get a new 20 amp switch at Home Depo or equivelant. Green screw is ground. otherwise it is foolproof. With the one you have you can wire one wire on the silver screw, and one on a black screw and it will work the same. you might change which way it is mounted so on is up.
Aug 17, 2009 | Cooper Wiring Devices Brown Switch 1 Pole,...
Ps  P&s Double Pole Lock Switch 20a 120/277v 20ac2-l Logo
90 people viewed this question
Top Ps Electrical Supplies Experts
Steve
Gene Haynes
Are you a Ps Electrical Supply Expert? Answer questions, earn points and help others
