Question about Kyocera Mita Office Equipment & Supplies
MAINTENACE TIME DISPLAYED ON MY km-2030 - Kyocera Mita Office Equipment & Supplies
  • Leroy Elliott
    Leroy Elliott Jun 02, 2010
    Yep, call a technician
    President:
  • 3,085 Answers
You need a technician to install a Maintenance kit. It consists of a new drum, developer unit, fuser and feed rollers.
Posted on Jun 04, 2010
  • Shawn
    Shawn Mar 06, 2011
    The message can be reset without parts. The message indicates it is time for items to be replaced based on the page count and when the items were replaced before.
    Use the mimetic keys and key in 10871087 and maintenance mode should be on the display.
    Key in 251 and press start key.
    Clear the count and press start and count will be cleared.
    Press stop key twice,key in 001, and press start key. The copier will go back to the ready state.
    Ensure you do not go into any other maintenance mode, you could cause major issues with your machine.
I hit duplex, then 2 sided and get a cannot combine error
Right, you can't use both at the same time. Try only one at a time.
May 10, 2015 | Kyocera Mita KM 1530/ 2030 Copier Machines...
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
My kyocera mita km 2050 displays its time for maintenace
You need to organise for a technician to come and service the machine.You can continue to use the machine.
Mar 31, 2013 | Kyocera Mita Office Equipment & Supplies
Coming with message on display maintenace required call for service
What is the error code that is being displayed? Is it displaying "Time for maintenance"? If there is no error code and the copier still works, it means the internal count has got to a factory set meter to have the drum & developer and possibly other part replaced at that time.
Oct 08, 2012 | Sharp AR-310NT Toner
I have error C200. How do I fix it?
you have a broken gear in the maindrive motor gearbox
Feb 20, 2012 | Kyocera KM-1505 Copier
I have classic model KM-2030; need code to change paper size from 8-1/2 X 11 to A4. Thank you!
Setting the destination Description
Switches the operations and screens of the machine according to the destination.
Purpose
To be executed after replacing the backup RAM on the main PCB or initializing the backup RAM by running
maintenance item U020, in order to return the setting to the value before replacement or initialization.
Enter Maintenance Mode
Enter "10871087" from keypad, You should now be in maintenance mode.
Enter "252"press "Start / Print" key.
Select your destination from list on the display.
Press "Start / Print" key.
Enter 001 "Start / Print" key to exit to normal display.
Method
Press the start key. The screen for selecting an item is displayed.
Setting
1. Select the destination using the cursor up/down keys. The selected item is displayed in reverse.
Display Description
JAPAN METRIC Metric (Japan) specifications
INCH Inch (North America) specifications
EUROPE METRIC Metric (Europe) specifications
ASIA PACIFIC Metric (Asia Pacific) specifications
2. Press the start key. The setting is set, and the machine automatically returns to the same status as when
the power is turned on.
Completion
To exit this maintenance item without changing the current count, press the stop/clear key. The screen for
selecting a maintenance item No. is displayed.
Feb 09, 2011 | Kyocera Mita RADF-11 REVERSING...
Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
May 27, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Km-2030 Checksum error f1
my copier is displaying error code 100, whats the problem km 2030
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
371 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
