How do I get to the door latch to repair it or replace it?
STEP 1:Grasp the handle on the Whirlpool oven door and open it to the first position.This will be a 4-inch opening
STEP 2: Place your hands on either side of the oven door
STEP 3: Pick up the door from the first position gently.Keep lifting the oven door until the door is clear of the hinge.
Thanks
Hi
There could be couple things. First, try pushing the door closed
as you turn the handle. The latch may have dropped into the strike hole
completely, binding the latch. Or you may try lifting the door as you try and
open it. Friction is the one thing that most often happens causing a latch not
to retract.
Another possibility is that the latch may have become detached from the knob
set. If this is the case, you will have to remove the lock from the door, and
from there you can open the door with a flat blade screwdriver. I recommend
replacing the latch as well. If you remove the lock from the inside of the
door, using a flat blade screwdriver you can pull the little 'T' that sticks
out from the latch on the inside of the hole. This pulls the latch back away
from the strike, allowing you to open the door.
There are different configurations of latches, and they activate like way. You
could run into a long latch the lock runs through. You can use a large flat
blade to activate that. If you have the type with the half moon, use the
outside of the lock body, stick it into the half moon, and turn the whole thing
to retract the latch.
Please get back to us if you have further query or else please
accept the solution.
Thanks for contacting fixya.com
Hello &
Welcome to FixYa
The beep
sound in oven is caused when either the door latch mechanism goes bad or the
control board itself is bad. First check the door latch...if the problem is still
there then replacing the control is recommended repair. Please get back to me
if you have any other questions.
Kevin
