Home | Tally | Matrix T2280 Printer | THS Error on war...
Tally Matrix T2280 Printer
Problem for Tally Matrix T2280 Printer
THS Error on warrantee printer tally serial printer
By fluy on Apr 09, 2008
Hi. The error message, on the tally 2280+ serial printer, displays "THS" error on the display panel. Can this be solved without accessing to the hardware parts?
Same Problem
Jun 20, 2008
-   i have one tally 2280 printer its showing ths error 011 in display panel , if there is any option to disable ths error in display panel ..
pls help me to solve the problem
-   sara_sathyam
Best Solution
posted on Oct 01, 2009
Very Helpful)
Jamming
Rank: Guru
Rating: 92%, 18 votes
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Feb 01, 2009
Somewhat Helpful)
SWARNAVA
Rank: Wiz
Rating: 77%, 32 votes
Yes it can be solved without accessing your hardware , THS -errso means thermal sensor error. just calibration the sensor from printer settings . your problem will be solve.
Was this helpful?
Yes
No
Popular Solutions for Tally Matrix T2280 Printer
Questions and Unsolved Problems for Tally Matrix T2280 Printer
Do you recommend Tally Matrix T2280 Printer?
Answer
Answer
Hi, Iam Having problem to work with tally 4.5 in xp giving the error message that insufficient dos... (More)
Answer
Describe your Tally Matrix T2280 : power up printer comes with THS ERROR 001. but still able to come... (More)
Answer
i cannot attach any file to sent e-mail
Answer
I have a tally printer that needs setting up. Can someone help with the procedure for setting up... (More)
Answer
T2280 Sprintpro Printer is giving AGA error
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tally Matrix T2280 Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 500
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
