Question about Logitech Pocket Digital Digital Camera
Battery problems? When Camera (Pocket Digital 130) is plugged into USB, it will not charge. I assume that it could be a battery problem? For instance, when It has been plugged in for two hours, it shows no sign of a charge. Can I buy a new battery if that is the problem? Installation? Please advise. Charles
  • cwsabicsr Jun 02, 2010
    I changed the location of the USB plugin. It seems to have worked. If it holds up in the next day or two I'll know that the problem is solved.
    Thank you.
    Charles
  • 6,487 Answers
Yes this is a battery problem, but having it replace is not easy to do and it very hard to find a replacemnet battery for that unit since its a Proprietary Lithium Battery that only Logitech has it. So the only way to have the battery replace is to take it to a Logitech service center on your area to avoid further problem on it.
But by the way before you to take it to a service center try to connect first the camera to a different USB port on your computer probably the back USB poirt or better try to connect it on a different computer because sometimes its a low USB port port that might be causing the problem. But after you tried that and still same problem now continue with the battery replacement from a service center.
Posted on Jun 02, 2010
M530 Digital Camera, how to charge it
Assuming you're referring to a Kodak M530, you can charge the battery in one of two ways:
  1. Use the supplied USB cable to connect the camera to the supplied adapter, and plug the adapter into a wall outlet.
  2. Take the battery out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
If it's not a Kodak M530, please reply to this post specifying the make of the camera.
Dec 17, 2010 | Cameras
Tip
DIGITAL CAMERA MAINTENANCE
charge battery after every use
always remove battery when not in use
be smooth while inserting and removing usb cables
keep clean the camera case (leather cover / cloth cover)
never keep digital camera in your pant pocket (back pocket)
gently clean barrel unit (lens assy) before switch off digital camera
on Feb 06, 2010 | Cameras
Will a usb cable fitting the Vivi Cam 8025 charge the lith battery; I can't locate a port on the camera to plug in a wall charger?
Yes, you can charge the 8025 through the USB port, assuming the computer puts out enough current to do so (not all USB ports do). Or you can take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet.
Dec 04, 2010 | Vivitar ViviCam 8025 Digital Camera
I have the powershot SD3500IS abd it says i need to change the battery pack what is that and how can i fix it also if i dont have a charer can i charge it with the usb ?
"Change batter pack" means your battery is dead. The camera should have come with a charger in the bok that can plug into the outlet in your wall. It uses a lithium ion battery, so you can't use a regular AA batter charger, for instance. You cannot charge the battery via the usb into your computer.
Nov 06, 2010 | Canon PowerShot SD3500 IS / IXUS 210...
Charging batteryif i dont have a device to charge the actual batt
Yes, assuming the USB port into which you plug it provides enough current. Not all computer USB ports put out enough current to charge other devices.
Jul 11, 2010 | Vivitar ViviCam 8025 Digital Camera
My logitech 130 camera's not charging properly
http://www.logitech.com/index.cfm/480/3398&cl=us,en?WT.ac=sc|downloads||dd
Jul 19, 2009 | Logitech Pocket Digital 130 Digital Camera
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Jazz DV 179 Camcorder
I believe that the camera will not charge directly from the computer - testing this theory myself... however I went to Radio Shack tonight and they have them there for 30 bucks (a bit outragious if you as me)
Jul 24, 2008 | Jazz DV-179 Digital Camera
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Logitech pocket digital camera
Same happening to me. The solution is to try it in a different USB port, as it is a USB related issue.
Feb 10, 2008 | Logitech Pocket Digital Digital Camera
Logitech Pocket Digital Digital Camera Logo
110 people viewed this question
Top Logitech Cameras Experts
Steve
Are you a Logitech Camera Expert? Answer questions, earn points and help others
