My washing machine fills with water and has an aggitation cycle, but does not pump out water or spin. It does not have a belt or pulley. The lid switch fell apart when trying to look at it. Is this the problem? How can you tell if it is this compared to the timer or water pump. I do not hear any motor humming when I put knob in the position for draining or spinning. Thanks, Joyce
  • 2 more comments
  • joycemermini Jun 02, 2010
    Thanks for the info. I found the videos extremely helpful!
    Jun 02, 2010 - Thanks for info. I do have the # for the switch and where to buy it. I want to ask about a lack of motor sound or humming when I turn knob to drain and spin. Is this an indication of somehting bigger than the switch? Also, do you have a video on by-passing the switch to make the spin cycle work? Lastly, the washer is a Kenmore, Stylemaster #909957-12-15 years old. When do I say the washer is done?
    Thanks,
    Joyce
    Thanks. I thought of one more thing. If it is the switch, would the machine still fill with water and go through aggitation cycle?
    Joyce
  • joycemermini Jun 04, 2010
    Hi Phil,
    I did the switch by-pass and was able to get the drain and spin cycle to work. So I replaced the switch and all is well in the world. Thank you for your help!!! The videos were especially helpful.
    Another question concerning a clothes dryer. Someone noticed a slight smell of gas in the laundry room. Put soapy water on gas connection and noticed some bubbles. The pipes were tightened and still there is a little leak. Could I shut off gas, clean all parts with goop cleaner and start all over with fresh pipe joint compound? Let me know what you think.
    Thanks,
    Joyce
    President:
  • 949 Answers
Hi Joyce,
Yes indeed you are on the right path. The washer is designed so that the spin cycle will not work with the lid open, so if the switch breaks or fails the machine thinks the lid is open and will not spin.
To verify this you can bypass the switch electrically and see if the machine runs. I do not know your level of electrical expertise so please ask any questions of me where I am not being clear, and forgive me if I am going into too much detail.
I am going to attach a link to a website that has a couple great videos showing how to take the console apart and replace the lid switch, because I do not know your exact model number I can't say which one pertains to yours but it will be covered.
To bypass the lid switch first unplug the power cord from the wall (safety first).
Lift the console(videos will explain this), that will expose the lid switch harness connector, unplug this connector and connect a jumper wire between the two outside terminals on the wire harness you just took off. making sure the jumper is not touching metal or you, test to see if the spin works.
Since you know this switch is broken already it may be wise to replace this without doing the jumper test if you are not comfortable with it.
If you could send me the complete model number from the tag that is visible with the lid open I can find the part number you need.
Let me know if you have questions. ..... Phil
Lid Switch Videos
Posted on Jun 02, 2010
  • 3 more comments
    Thanks,
    Joyce
  • Philip Jun 02, 2010
    Hi Joyce,
    As far as the motor not making any sound during drain or spin: This would be normal with a bad lid switch. The lid switch will disconnect the power to the motor so if were making a noise the switch would not be bad.
    When to say enough is enough: That is a very hard call to make, typically when the repair cost is over 1/2 the cost of a new machine I recommend looking strongly at a new machine. One thing to know is that new machines are more energy efficient so will cost you less to operate. With these energy savings comes a price, you do not not use as much water, so how you do laundry, types of detergents will change, so if you are very comfortable with what you have, that should weigh into your decision. I know I am dancing around your question but there is no real good answer for this one, I am biased because I am in the service and repair field.
    I will look for something here that at least has a picture of bypassing the switch for you and send it along in a bit or a note.. so stand by for that.
    Phil
    Hi Joyce,
    Here is link to a couple of pictures, it is showing the washer with the cabinet off, you can do it with the cabinet on and the console up.
    They are using a piece of wire that is 'stripped bare' on the ends exposing the copper, and putting that piece of wire into the outside wires in the harness connector. If I run across a better one tonight I will forward on. Click the next links on the website to advance frames (not exactly a video, but if you click fast......) sorry a little web humor
    Take care,
    Phil
    Lid Switch Bypass
    Depending on the model most of the machines will fill and some will agitate with the lid up, but none will drain and spin.
  • Philip Jun 04, 2010
    Hi Joyce,
    I am glad the washer worked out for you.
    Depending on the type of gas connection you may be able follow your proceedures. If it is a pipe fitting then yes. If it is a compression fitting or flare fitting clean them and do not use any compond on the threads.
    Typically taking apart, cleaning and resealing works well. Check good with bubbles and clean off any soap reside when finished.
My machine don't engage in spin cycle
If your washing machine is not spinning or gets stuck in between a spin cycle you need to check for these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank You for contacting Fixya.com
Nov 26, 2009 | Maytag PAV2300 Top Load Washer
Will not cycle
Nov 26, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Kenmore top loading washing machine manual for 110. Machine does not activate pump to empty water. Also, spin cycle does not work. Machine will fill up OK and aggitate OK.
Check the lid switch for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2009 | Kenmore Washing Machines
Washer will agitate but does nothing through it's spin cycles. The timer advances through the spin cycle but you can't hear the motor run or even try to start, Washer is aout eight years old.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
as you mentioned timer advances,then check out cold water entering the machine or not. If your washer won't spin, check these:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jul 13, 2009 | Maytag Washing Machines
Jetstream 1400.Zanussi Front Load
buzzing indicater mostly motor problem.other possibilitires are  It doesn't spin If your washer won't spin, check these:
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
There's no water at all If there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
May 07, 2009 | Zanussi FJS1225W Front Load Washer
Washer will only wash.
A Clothes Washer with the complaint of "Fills, Agitates, But Does not Drain or Spin" can be:
Defective Door/Lid Switch (Very Common): The lid-switch "that clicking sound you may hear when opening/shutting the door" can become defective after constant "slamming or dropping" or the door. This switch is a relatively simple repair. The lid switch can be located on the inside top of the machine and can be typically removed by (2) screws and un-plugging the electrical from the inside. The lid-switch costs about $15 or so for the part.
Drive-Belt or Coupling (Common) - You may have either a belt or coupling that may connect to the motor, transmission (pulley) and pump (on direct-drive machines). The belt and coupling is the driving force that engages your tub to spin and drain. Typically, upon receiving power from the lid-switch at beginning of rinse cycle, the "drive-train" (motor, transmission and water-pump) is "kick into action". Belt-Drive Machines: The belt is fairly simple to replace and runs about $20 or so. The belts circles and inter-connects with the Transmission Pulley, Motor Pulley or even with the Water Pump Pulley (Metal Cylinder type with belt groove). Direct-Drive Machines: The coupling runs about $10 or so is a little more complicated to repair. The coupling is a total of (3) small - inter-locking plastic components located and attached between the motor (mounted to shaft) and transmission (mounted to shaft) and enables the transmission to spin, upon motor receiving power.
Timer Control - (Very Uncommon)
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
I have an Indesit washing machine and I get error message F-10 . It won't drain or spin and doesn't do a complete washing cycle. I have an Indesit WIE127 washing machine and I get error message F-10 after...
hi there,
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Jun 24, 2008 | Indesit W 123 Front Load Washer
Washer not spinning at the spin cycle but water drains
hi there,
repair technician.
the entire motor.
May 05, 2008 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
