Question about Compaq Presario Fan
I HAVE A COMPAQ PRESARIO SR1339UK, THE PLASTC
I HAVE A COMPAQ PRESARIO SR1339UK, THE PLASTC MOUNTINGS ON THE HEATSINK FAN HAVE BROKEN, FOUND FAN NUMBER AND NAME BUT CANT SEE ANYTHING LIKE IT ONLINE, (ASIA), IS THERE AN UPGRADE OR PART NUMBER FOR THIS...THANX . ANY HELP WOULD BE APPRECIATED, I'M A NOVICE, BUT I'M WORKING ONIT...
    Champion:
  • 253 Answers
You can install an other cpu cooling.
You have to find out which socket the cpu got and the size .
it has to fits to your pc case.
Look for some videos on youtube .There are some good guidlines
for cooler installin.
A cpu cooler is not very expensive but most a time a lot better than the standart cooler.
Posted on Jun 02, 2010
I need to find an CPU fans/Heatsink Part for my Compaq Presario Laptop Does any body know where to get tham at and cheap to??
you no need to change the heatsink only need to change the fan and visit your nearest whole seller and tell me to give you a one fan for your laptop. dont change the heatsink ok . just clean it well. may i know why you are chaning your fan? you having a slow speed of fan? just open the steaker of fan and you can see the hole there just put the few drops of oil and then try.
Apr 19, 2011 | Compaq Computers & Internet
Hello! am using compaq presario CQ40. i bought it before an year. i have a problem in the display screen. when i switch in the laptop, i found some lines flickering at the bottom of the screen. i found the...
This is rather LENGTHY and detailed dhivi, advising you in advance.
All of the components for a laptop are crammed inside a tiny box with a poor cooling system.
The cooling system consists of a small fan and Heatsink. (Fan/Heatsink Assembly)
The Heatsink Assembly is shaped like a U for the Compaq Presario CQ40 series.
The U shaped Heatsink Assembly is composed of a finned Heatsink, Cooling Tube, and metal plates (2) attached to the Cooling Tube.
The finned Heatsink is on one end of the Cooling Tube, with the 2 plates of metal spaced around the Cooling Tube away from the Heatsink.
The 2 plates of metal sit on top of the Processor, and graphics chipset.
One on the Processor, one on the graphics chipset. (GPU. Graphics Processing Unit)
The Cooling Tube is a hollow copper tube slightly flattened, and filled with Nitrogen gas.
Heat is absorbed by the plate on top of the Processor, and plate on top of the graphics chipset, and transferred to the Cooling Tube. The Cooling Tube absorbs the heat, and transfers it to the finned Heatsink.
The Heatsink then radiates the heat away. Air flow from the fan flows through the fins of the Heatsink, and helps carry the heat away.
Underneath the two metal plates is a thermal medium.
For the processor, Compaq used Thermal Paste.
For the graphics chipset they used a Thermal Pad.
Below is a link for disassembling a Compaq Presario CQ50, CQ60, or CQ70 series laptop.
VERY similar to the CQ40 series,
(Your laptop is one of the Compaq Presario CQ40 series of Notebook PC's. The exact Product Number is on the bottom of the laptop in a white Service Tag. P/N = Product Number)
http://www.insidemylaptop.com/remove-motherboard-from-compaq-presario-cq50-cq60-cq70-laptop/
Scroll down the page, and view Steps 20 and 21.
This shows you what your Fan/Heatsink Assembly looks like.
(Also a good guide for disassembling your laptop)
In Step 21 you see the Fan/Heatsink Assembly removed.
Looking at the two chipsets on the motherboard,
1) The Rectangular chipset on the Left, is the Processor
2) The Square chipset on the Right, with the purple diamond in the middle, is the graphics chipset
The purple diamond is a Thermal Pad.
In my opinion a Thermal Pad is junk.
Thermal compound (Paste) is interweaved in the fabric of the Thermal Pad.
Thermal paste dries up after being repeatedly exposed to heat.
This is why the top of the Processor, and bottom of a Heatsink on a desktop computer, needs to be cleaned off, and new Thermal Paste applied every so often. The Thermal Paste dries up, and loses it's conducive properties. (Even if it's Artic Silver 5)
Primer:
The top of a Processor, and bottom of a Heatsink are not perfectly smooth. A microscopic view would reveal, 'Pits, Hills, and Valleys'.
This imperfections create air pockets when the Heatsink sits on top of the Processor.
Air is an Insulator, not a Conductor.
Thermal paste fills these voids, (Imperfections), and is an excellent conductor of heat.
It helps transfer the heat from the top of the Processor to the Heatsink.
Same thing for the two metal plates which sit on top of the Processor, and graphics chipset in a laptop. The top of the Processor, and the top of the graphics chipset are not perfectly smooth.
Neither is the 2 metal plates which sit on them.
The Thermal Pad has dried up, and is allowing the graphics chipset to overheat.
This is what causes the lines you see in the LCD screen.
The Thermal Pad should be removed, and the top of the graphics chipset Thoroughly cleaned.
Also the top of the Processor.
The bottom of the two plates of metal should also be Thoroughly cleaned.
Then new, fresh Thermal Paste should be properly applied.
The Thermal Pad can dry up in a laptop in a years time.
To add:
The graphics chipset is surface mounted to the motherboard.
The Processor in a Compaq Presario CQ40 series Notebook PC is an Intel Core 2 Duo T7300.
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Dual-Core_Notebook_processors
The processor socket is a Socket P.
The processor has the pins, the Socket P processor socket has the socket holes.
478 of them.
http://en.wikipedia.org/wiki/Socket_P
The mounting of the graphics chipset is a surface mount called BGA.
Ball Grid Array
Instead of pins on the bottom of the graphics chipset there are solder balls.
The surface of the motherboard has matching Copper Pads.
The graphics chipset is set on the motherboard's copper pads, and heat is applied.
The solder balls melt, and solder the graphics chipset to the motherboard.
With constant overheating due to the thermal pad has dried up, or due to overheating in general, the solder joints start to melt, and the graphics chip loosens from the motherboard.
This causes a poor connection, and the results may be what you are seeing with your laptop.
This is one solution for that particular problem,
http://www.youtube.com/watch?v=bnkQNmKauEc
This is another solution,
http://www.youtube.com/watch?v=vR8L3B3eDr0&feature=related
This is the download page for the Service Manual (Free) for the Compaq Presario CQ40 series of laptops.
I chose the Compaq Presario CQ40-200 CTO Notebook PC, but the Service Manual is for all of the CQ40 series,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3767562&
Click on the file name >
Compaq Presario CQ40 Notebook PC - Service and Maintenance Guide
After you click on the link it may take up to 30 seconds before you see the first page, and addional time for the PDF file to fully download.
Regards,
joecoolvette
Nov 27, 2010 | Compaq Presario Notebook
What will be the possible cause when my laptop compaq presario C700 is automatically turning off?
If the laptop shuts down and won't boot up until it has cooled down, then the CPU is overheating and goes into thermal shutdown. This is caused by either a faulty fan or the fan and heatsink assembly is clogged with dust.
If this is not fixed then eventually the CPU will fail completely.
Check the fan to see if it spins freely if not then replace the fan.
If the fan and heatsink is clogged with dust then remove the dust from the fan and heatsink fins.
Aug 24, 2010 | HP Compaq Presario C700T
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
V2311US overheating and shutting down
Try to clean heatsink and fan. Make sure fan is spinning(common problem).
Mar 20, 2009 | HP Compaq Presario V2311US (EC186UA) PC...
Compaq Presario M2000 - Fan not running
It appears your CPU is overheating and is shutting down.
Does the fan spin at all when the laptop is switched on?
The fan could be faulty, if it does not spin freely.
To test the fan, try removing it and connect it to a 12 volt DC power supply, if the fan spins fast then it is OK and the fault is on the laptop, possibly the power supply to the fan. In this case you need professional help.
If the fan appears OK then the problem could be insufficient too old heat sink compound between the CPU and the heatsink. You will need to remove the fan and heatsink and the old compound and put some fresh heatsink compound on the CPU/heatsink and reassemble the fan/heatsink.
Dec 29, 2008 | Compaq Presario M2000 Notebook
Compaq Presario V5000 Fan noise
YES ITS EASY AND ITS JUST DIRTY TAKE IT OUT AND CLEAN IT IF YOU DO NOT KNOW HOW TO JUST USE A VACUUM OR A HIGH PRESSURE AIR BLOWER HOPE IVE BEEN A HELP
Jun 26, 2008 | Compaq CPQ/ SPS Evo Laptop Heatsink-Fan...
Heatsink fan
is the fan running? if not try to replaced new CPU.
May 26, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
200 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
