Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
How do I change the plastic panel on the door?
    Champion:
  • 246 Answers
You may not have to, go to www.applianceart.com to see many options that go over your current panel. They also have stainelss replacement panels. The only dishwashers that have panels that you can replace are "frame" dishwashers. If you have one of these, there will be two screws on the side of the door that, when unscrewed, release one side of the frame allowing you to slide the panel in and out. If you dishwasher has metal that wraps around the side, you may want to trya vinyl and a stainless steel foil option that wraps over your door around the sides. Also available at applianceart.com
Posted on Jun 07, 2010
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
I purchased a replacement side view mirror for a 2010 Silverado. I need to remove the door panel to get to the wiring connection How do I remove the door panel?
Try with this procedure...
1) Start with opening the driver's side door and lowering the window. Remove lock lever (1A).
2) Using a plastic pry bar [slotted screwdriver], slowly pry plastic cover to reveal screw.
CAUTION: These plastic covers are fragile and break easily. Be very gentle in disengaging them.
3) Remove screw with a 10mm socket.
4) Slowly pry plastic cover using a plastic pry bar [slotted screwdriver].
5) Remove the (2) revealed screws with a 10mm socket.
6) Pry off the door panel controller using a plastic pry bar. Disconnect wiring and remove the controller.
7) With the plastic pry bar, pry around the triangular panel as shown.
8) Lift up and slowly pull door panel out partially.
9) Release the door lever rod with a needle nose pliers. Remove and set door panel aside.
Keep us updated.
Jan 11, 2011 | 2009 Chevrolet Silverado 1500
Describe how to change the passenger mirror on a 2007 Toyota Sien
Hi, First remove the door panel. (The connector for the mirror is behind the panel just to the left of the door handle.) The arm rest cover pops off by gently prying upward at the corners near the door panel and along the outer edge of the arm rest. Then remove the 2 screws. Remove the screw that holds the door handle bezel on. Remove the little plastic plug to the left of the door handle as well. This reveals yet another screw to remove. Now you can gently pull the door panel away from the door. The little plastic clips will pop out of the door. If they come away from the door panel they easily fit back in place in the metal retainers built into the door panel. You can now disconnect the connector and remove the 3 10mm mirror bolts.
With respect to the door handle bezel on the inside of the door, to remove it you must pull/slide the bezel away from the door hinge. It should move an 1/8 to 1/4 inch. There is a little tab that hooks inside the door handle mechanism and two small holes, top and bottom, that slip over little pegs on the mechanism. I broke this tab while removing the bezel on my car. This was the most difficult part, on my car, to remove.
Take care
Jul 23, 2010 | 2007 Toyota Sienna
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
How do you change a passenger mirror on a 2006 Chrysler Town & Country. The mirror is not broken just the plastic frame work.
If you're lucky, on the inside of the door, will be a triangular panel right behind the mirror that you can pop off. If you're not as lucky and it's one piece or the panel is blocked by the door panel, you'll need to remove the door panel to change it.
On the inside trim, you can remove screws (these screws may be covered by filler pieces or may be visible, or they may require you pry a plastic piece off that covers the screws) that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can remove the bolts holding the mirror onto the door
Nov 09, 2009 | 2006 Chrysler Town & Country
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Removing inside door panel to change the speakers
Door panels are easy, first remove all of the screws, some will be hidden under plugs on the door handle. Using a door panel tool (about $5.00 at a parts store) work it around the panel and pop the plastic keepers out. Done.
May 28, 2009 | 1998 Toyota Corolla
Replacing 2003 zx2 driver side power mirror.
Its "doable" but I wouldn't advise you to do it that way. Get a phillips screwdriver to unscrew the elbow pad & any other screws holding the door panel on. Disconnect the pwr window switches & any other switches on the panel. On the lower end of the door panel there are plastic clips holding the panel to the door. POP them out of the door & remove the panel. disconnect the mirror electrical connector & disconnect the mirror body itself. Install the new one & don't forget to connect all of the electrical connectors & reinstall the panel. Good luck
Jul 17, 2017 | 2003 Ford ZX2
How to replace door switch on 2001 Plymouth Neon?
witch door switch
if it's electrical you simply unscrew the door panel if it's never been off pull the plastic sheet also not to tear it on the back of the door panel you'll find you're door lock and window switches some times you can exchange switches some times you have to change door panels depends on if you can dissasemble the panel correctly and what you do or dont break
Jul 29, 2008 | Plymouth Neon Cars & Trucks
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
77 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
