Question about Whirlpool ET8CHEXSQ Dryer
Can rollers that the drum rides "on" be lubricated?
  • Whirlpool Master
  • 7,482 Answers
Yes, the rollers can be lubricated...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on Jun 03, 2010
Lavatherm 320 - can the drum be greased
On the outside of the drum I hope! It can be lubricated, Grease will attract the lint, and the dryer surely emits lint. If it is squalling it's more than likely a bad Roller that the drum rides on. It might stop if you spray some Silicone on the center area of each roller. You might have caught it soon enough to keep it from totally freezing up.
Jan 17, 2013 | Dryers
Dryer tries to turn but then shuts off
Hi espichfamily
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley this will cause the drum not to roll.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
Please take time to rate me
Bud
Oct 11, 2012 | Amana NED7200TW Electric Dryer
Why does my dryer make loud sqeeking noises while running
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
pulley and motor.
3 in One oil.
Please rate me
Dec 07, 2010 | Frigidaire FGR641F Gas Dryer
Electric dryer makes a screaking sound when tumbling.
That is usually the drum front bearings--either flat strips of Teflon attached to the front panel opening edges or a set of rollers that the drum rides on. Remove the cabinet top (either screws front/back or spring clips in the front corners that are pushed back with a thin putty knife to release). If the front panel is releasable, it can be removed by removing screws from the inside in the corners. In the case of Teflon strips, the plastic and drum surface must be cleaned--no lubrication necessary. In the case of rollers, each has a bearing that may need replacement or just lubrication (3-1 or similar oil) to stop squeaking. Hope this helps!
Mar 02, 2010 | Dryers
My dryer makes a scraping noise when the bowl
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
Good Luck,
I hope this helps
Oct 29, 2009 | Frigidaire Dryers
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 10, 2009 | LG DLE5977 Electric Dryer
Making a noise when drum is turning.like a vibration
replace them.
you noise problem.
Good Luck,
I hope this helps
Oct 08, 2009 | Kenmore Dryers
Very noisy vibrating sound when dryer is turned on.
You problem sounds to be noisy drum rollers.
Drum rollers will get flat spots on them and over time they will need lubrication.
If you have a front load machine, then you would normally remove the front and this will expose the drum...remove the drum and this will expose the drum rollers.
If you have flat spots on the rollers replace them...if they are in need of lubrication you can use a good grade of machine oil...such as 3 in one oil. You would oil the shaft of the drum roller.
If this does not solve the problem, then you may have to replace the drum rollers
I hope this helps.
Oct 01, 2009 | Amana Dryers
Dryer has a loud squeaking noise when you first start it up
Sounds like your drum rollers need lubrication or replacement.
If you have a front load machine, remove the front of the machine, this will expose the drum. Remove the drum and this will expose the drum rollers. Lubricate the drum rollers with a good grade of machine oil like 3 in One oil at the shaft.
Hope this helps
Oct 01, 2009 | Hotpoint Dryers
Squeaking
The squeaking is usually attributed to any (or all) of the following:
The drum support rollers
The rear drum seal
The front drum ring bearing
The front drum seal and bearing assembly
The Idler Pulley
Now before you throw yours hands in the air in a panic, these parts sound more technical than they are. All the bearings and seals for the drum are either felt or plastic, the drum rollers support the drum at the rear bulkhead, and the idler pulley is what the drive belt rides on. Searspartsdirect.com offers excellent illustrations to show you where these parts are located. Just type in your complete model number and there will be a part listing with part numbers on the next page. If the model number you posted this under is correct the parts can be found under the following headings:
"Bulkhead Parts"
Drum Support Rollers (item 44) Part #349241T (pkg. of two)
Rear Drum Seal (item 66) Part #279857
Front Drum Ring Bearing (item 62) Part #279441
"Cabinet Parts"
Drum Seal and Bearing Assy. (item 38) Part #3406129
Idler Pulley (item 53) Part #691366
I list all these parts as a convenience in case you need to order any of them, and to help illustrate where these parts are located. You may not need ANY of them.
The drum support rollers require lubrication at the point where the roller meets the shaft with a light turbine oil. This should be done periodically to keep them rolling smooth. DO NOT get any oil on the rubber rollers or it may cause the drum to slip. You should also remove any build of lint before lubricating.
The drum seals can become brittle with age and start making noise as the drum rotates. This is particularly true with the rear drum seal. It will become discolored with age and turn brown in many cases. Inspect the front and rear seals of the drum for excessive wear. If parts of the seal begin to protrude into the interior part of the drum, this is a good sign that the seal is bad. The seals cannot be lubricated and will require replacement.
The idler pulley is a small plastic wheel on a shaft that the drive belt rides on. Lubricating the idler pulley wheel in the same manner as the drum roller supports is also required from time to time. DO NOT get any oil on the drive belt.
I know this seems like a lot, but a simple matter of cleaning and lubricating may be all that you need. If you require further assistance, please let me know. I hope this helps you.
Jul 24, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool ET8CHEXSQ Dryer Logo
64 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
