Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washing Maching fault code F70
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F70 is a communication error between the Central control unit (CCU) and the user interface. To start with you’ll need to check continuity of the user interface and then check the wire harness connecting the user interface & central control unit. If the drum is not moving then central control unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
F70 code says...
Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
The control board is part # 14 in the link below.
Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
Mar 13, 2015 | Whirlpool Washing Machines
Washer won't start.....F70 code appeared It's a Whirlpool Duet
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Getting code F70 and F71.
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool Duet washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 70 error on my whirlpool duet washer
Hi, F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board which needs to be replaced.
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F70 mhwe900vj00
What is f70? is that an error code? there is no f70. there is an f07 code.
http://www.repairclinic.com/0078.asp
there it will tell you what f07 means and what to check
but if i am way off tell me what exactly you want to know thanks
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting the F21 flashing on my Whirlpool Duet Washing maching
To know what the f21 means, You need to see the fault code list; this is on a tech sheet that is usually taped to the back of the machine, orit is in the contol compartment that you will have to open to access. Note: the newer whirpool units have end caps that must be removed by light prying in order to access the screw on each side that releases the component compartment . Goodluck, Macgivor
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
667 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
