Question about Dishwashers
Ge adora dishwasher water won't fill
Ge adora dishwasher When I turn on the dishwasher it goes through the cycles, but it won't fill with water
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
I had the same problem. All I had to do to resolve the issue was disconnect the water supply line under the sink and blow into it a few times. Hooked it back up and works like new. Hope this helps.
Posted on Apr 04, 2013
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Dishwasher isnt filling up with water the arms inside arent spinning and it shuts off after 3 minutes.
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 30, 2010 | General Electric Adora GHDA670N Built-in...
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
5 yr old GE Adora -- have it repaired or replace?
look in the back and make sure the drain hose is about 18 ins high if the hose falls it will not hold the water in the machine
Feb 10, 2010 | GE Adora GHDA656LSS Stainless Steel...
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Dishwasher with one inch of water in bottom when complete
undo the drain hose from your drain and put it in a 5 gallon bucket and see how it drains your sink drain maybe stopped up or if it drains into a disposal it may be stopped up
Apr 24, 2009 | GE Adora GHDA656LSS Stainless Steel...
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Dishwashers Logo
187 people viewed this question
Top Dishwashers Experts
Owen Barnes
