Question about Tappan TEF242 Electric Kitchen Range
Tappan Range fault code F10 when baking & oven gets too hot.
I have a Tappan electric range model # tef351ewe. Error code F10 appears after baking for a while, oven gets too hot, and only top elements heats. I can't find a Tappen error/fault code of F10.
MNTECH
  • 1543 Answers
SOURCE: Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Posted on Nov 08, 2008
duby1990
  • 370 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
  • 29 Answers
SOURCE: ge range electric oven won't heat up
WHEN BAKE CYCLE IS SELECTED?
Posted on Jan 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: TAPPAN RANGE
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
F10 fault
F1 through F10 fault codes are runaway temperature codes.
If this error code is shown while the oven is in day time mode, the Electronic Oven Control (EOC) would need to be replaced. Otherwise it may be the oven temperature sensor or Resistance Temperature Detector (RTD sensor).
Sounds like you will need to contact an appliance repair technician in your area to test each to isolate the problem.
Apr 13, 2014 | Frigidaire PLEF398AC Electric Kitchen...
I have a Tappan ES200 Electric Range that has error code F10.
What is the model number listed on the unit? Look inside the oven door area.
Feb 08, 2013 | Kitchen Ranges
Tappan Gas Range 36-30612302 oven does not get hot enough
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat to correct tempature that a weak ignitor is the cause 100% of the time
Aug 15, 2011 | Tappan TGF363 Gas Kitchen Range
Hi i own a tappan tgf328 gas range and I'm trying to heat up the oven and its beeping and giving me an F31 code. Can you help me?
Tamppan Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Apr 07, 2011 | Tappan TGF320 Gas Kitchen Range
Our electric tappan dual radiant baking and roasting oven is beeping and giving an f1 message
Hi gracie7773,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2009 | Tappan TGF320 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Tappan TEF242 Electric Kitchen Range Logo
719 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
