Question about Garden
I can't get my lawn tractor to start useing the sylinoide, I have to cross the battery cable with the starter cable
  • 420 Answers
Check the voltage to the small wires, if you do not have 12 volts to those the solenoid will not engage. Common reasons 12 volts will not go to the solenoid is a bad seat switch, brake switch or other safety interlock. If the solenoid DOES have 12 volts to the two small wires make sure the ends are nice and tightly connected to the solenoid, if all above are ok then replace the solenoid.
Posted on Jun 02, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Does a bad battery cause my tractor to not turn over?
Yes. Verify it is the battery by jumping mower off with car battery. If turns over, replace battery. If cannot turnover by jumping, try bypassing start solenoid by tapping positive cable to battery post on starter. Starter should turn. If starter doesn't turn, have starter tested.
May 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17.5 hp bolens lawn tractor motor turns slowlyand will not start. new battery, starter works. what is valve adjustment proceedure?
check the battery cable bypass them with jumper cables that engine uses a lot of amprich to spin it over valve adjustment would change all at once but i set mine to .006 when the opposite valve set the other one
May 11, 2012 | Ariens Garden
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Have a green light to start push button nothing this is a 1999 bigred atv
THE FIRST THING TO CHECK IS THE STARTER SYLINOID SOMETIMES JUST TAPING IT WILL DO THE TRICK ,,,THE WAY TO CHECK FOR SURE IS TO TAKE A FLATHEAD SCREWDRIVER AND CROSS IT FROM THE TWO WIRES CONECTED TO THE SYLINOID THIS WILL TELL YOU THAT ITS BAD,,,SIMPLE TRY IT WONT HARM A THING,,,,THEN YOU WILL KNOW ITS NOT THE STARTER,,MAY BE JUST A LOOS WIRE ON THE SYLINOID,,,, OH BY THE WAY ITS UNDER THE SEET..HOPE THIS HELPS.
Jul 13, 2011 | Yamaha RD 350 Motorcycles
My craftsman lawn tractor quit while cutting heavy grass. wouldn't restart..........pushed it to the garage............ took off deck......... still woundn't start replaced battery ......... still will...
Try using jumper cables and jumping from the positive battery post to the starter lug where the main cable hooks to the starter. If you don't have jumper cables find the solenoid on the inside of the right side panel. Pull the rubber caps off and jump that with an old screw driver if the engine turns and starts on either occasion it is the solenoid. Part # 192507 sells for about $15.00 at searspartsdirect.com
Oct 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower won't start
sounds like the ground cable is bad
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
