Question about Fagor 3FCA-68NFX Stainless Steel Refrigerator
Hi, I have a Fagor FC 47 fridge freezer and the warning light has come on. I have tried to turn off and on but it will not reset. Any suggestions Cheers Stuart
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Currently have a Kenmore 26 Porcelain plus. Fridge keeps beeping intermittently and ''warn'' and ''check food'' lights stay on. Both fridge and freezer seem to be working. Any suggestions?
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Then plug-in and follow instructions. Things will be good
Jul 30, 2010 | Kenmore Refrigerators
Fagor refrigerator (3FCA-68NFX): no cold air in the refrigerator
u may have a duct that goes from the freezer to the fridge that is closed off or u may have a stopped up freon line and if thats the case ur probably going to have to call a tech but check the duct first if u have one in that particular fridge
Mar 01, 2010 | Fagor 3FCA-68NFX Stainless Steel ...
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Sep 18, 2009 | GE PDS22LBN Bottom Freezer French Door...
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Servis fridge freezer
Try to unplug the unit to reset the error, but if the error persist please call a qualified technician.
Dec 20, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Hotpoint combination 8591
Look like your refrigerator ran out of freon.
Nov 26, 2007 | Freezers
Fagor 3FCA-68NFX Stainless Steel  Refrigerator Logo
69 people viewed this question
Top Fagor Refrigerators Experts
AJMAL KHAN
Chris Huff
Chris Huff
Are you a Fagor Refrigerator Expert? Answer questions, earn points and help others
