Question about Kenmore Refrigerators
Water under refrigerator - Side by Side Kenmore 106.58126700
SOURCE: Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Posted on Feb 16, 2008
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
  • 58 Answers
SOURCE: refrigerator/freezer
Seems that the condensate drain is clogged/frozen.. If there is a bottom storage bin on the freezer side, remove it. There should be a removeable panel on the back freezer wall. If you can safely remove it then do so. Look for an accumilation of ice behind the panel, under the evaporator coil. Do not attempt to do this unless you have a good mechanical aptitude. One other thing you may try is to clean the coil underneath the refrigerator. This can be quite difficult as the unit must be tilted in such a way as to gain access. The coil there is most likely covered in dirty hairballs. Once the coil is clean, let the unit defrost overnight. Once again, do not attempt any of these steps unless you are certain you can handle it. Perhaps it would be best to call a qualified service tech.
Posted on Sep 11, 2008
  • 48 Answers
SOURCE: My kenmore side by side refrigerator model
Icemaker leaks are common and cannot always be solved. May need a new Icemaker. Ofter you can obtain a kit from Lowes (use a Whirlpool kit.)
Posted on Aug 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: Kenmore side by side refrigerator water dirty
You may need to replace the water reservoir located behind the crisper. They are known to flake and cause the problem you describe. They are usually replaced with a coil of water line instead of one larger reservoir to stop the problem.
Posted on Oct 11, 2009
Ice and water on the bottom shelf of my sears Kenmore regular refrigerator. things are cold but water pooling on the bottom shelf.it is a Kenmore freezer on top and refrigerator on the bottom
Drain stopped up. Defrosting occurs and condensation water must be evacuated, this is done through a dran hole. Clogged drain means water inside under crispers messy all that luv. Find the drain hole and give her a good old clean out. All will be good.
Jan 18, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Side by side kenmore refrigerator 14 years old leaks water under left front
That coulds be a defrost drain blockage or the coupling to the water dispenser is loose. Remove the kick plate to see if the water is dripping from water line or look into freezer to see if water is draining from rear panel in freezer. Let me know what you see and I will be able to tell you what you need to. Sea Breeze
May 20, 2010 | Kenmore 57029 Side by Side Refrigerator
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Noise in the water system
I have tried 3 times to answer, so go to my site and read your answer under the parts search feature. Click link below
http://servicepartstec.blogspot.com/
May 15, 2009 | Kenmore 57029 Side by Side Refrigerator
Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Mar 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New refrigerator
A refrigerator must get rid of condensate and "frost". There is a collection pan under the back of the unit where there is also a fan that helps removes the excess moisture back to the atmosphere.
Jan 05, 2008 | Kenmore 44273 Side by Side Refrigerator
Water coming from under door
  The water line enters door thru lower hinge.  Check the connection by door hinge.  Remove toeplate to access this.
Oct 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
96 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
