Question about Craftsman 2500 PSI Briggs Stratton Powered Pressure Washer
Craftsman Pressure Washer 2.3 GPM 2550PSi
I was using my craftsman pressure washer for 3rd time. I had been using it for about 45min and it just stopped working. I had run out of gas. I filled tank with new gas and now pressure washer will not start. I waiting about 2 hours and tried to start it again. I have not been able to get this started...Any Advice?
  • 1 more comment
  • E00912 Jun 02, 2010
    wolverine494, thanks for the reply. There is no fuel filter on this model and its an "EasyStart" model its primer less. Any other suggestions.?
    This unit is primerless "easystart" system. There is not fuel filter either.
    This unit is primerless and has not fuel filter..its an "EasyStart" Model.
Your fuel cap has a venting system that runs through the threads and not a hole on top. If you tighten your cap to tight it will cause a vacuum build up in the tank and not allow fuel to travel to the carburetor. Hope this helps.
Posted on Jun 19, 2010
  • 391 Answers
If there is a fuel filter running completely out of fuel sometimes allows all of the bad stuff in the fuel tank to plug the fuel filter (if it has one). press the primer bulb until you can hear fuel, then it should start.
Posted on Jun 02, 2010
  • Mike Squire Jun 02, 2010
    Have you checked to make sure it has spark when you set the lever to start it?
  • Mike Squire Jun 21, 2010
    I would return it to the store unless you want to investigate further. You can remove the fuel hose from the carburetor to see if fuel is getting TO the carb at all, if yes then remove the float bowl by taking the nut off of the bottom. If fuel does not flow from the needle valve when the float swings down the needle valve could be a plugged or stuck. If the bowl was full of fuel and the needle valve works as it should the main jet may be plugged. The main jet looks like a brass screw that is slotted and screwed into the bottom of the carburetor. Remove it and blow out the tiny holes; once you do all of this it should elliminate any fuel issue and if it will still not start it must be electrical such as a bad plug or other grounding of the ignition system. Either way it should not be happening to a brand new machine. Mine is over three years old and not a single issue with the engine or pump yet so what you are experiencing is not normal at all.
I installed a new pump but doesn't have pressure.
Input and output are correct? Relief valve open?
Oct 03, 2015 | Craftsman Garden
Pump builds pressure but not full pressure on same faucet iv always used
possibly have worn seals inspect them and also unloader valve which normally has a spring
Aug 13, 2014 | Craftsman 2700 Max Psi Pressure Washer 23...
Cant find choke on craftsman 2700 2.3 ready start 7.75
If I remember correctly, there is not an operator actuated choke on that unit. It is thermostatically controlled be a device behind the muffler.
Aug 25, 2013 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Craftsman 2500psi 2.3 gpm briggs and stratton pressure washer wont start
if it is still within the warranty period , take it to an authorized service agent for a check
if not I would be looking at the fuel system ( water in the carby) or wires to the stop/.start switch
May 17, 2017 | Craftsman 2500 PSI Briggs & Stratton...
Craftsman 1700 leak
craftsman 1700 pressure washer 1700 elect. with steam
it sucks down the soap down when I wash my golf cart. I do it fast any way slowing it diwn
Jan 28, 2013 | Craftsman 1700 PSI, 1.3 GPM Electric...
I bought a new craftsman pressure washer 2700psi. Put oil and gas in it. Cranked on the first try. It worked for about 15 minutes and then cut off. Now the pull start is very hard to pull and will not...
Hello
Take out the spark plug and try pulling,if it is still hard then then there is a problem with the pull start mechanism.
Check the plug for oil fouling or fresh oil.If there is excessive oil you may have bad rings.
If in doubt, craftsman will honor the 1 year warranty no questions asked,for a new unit.
Jun 25, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Craftsman 2000 psi, 1.9 gpm pressure washer Manual
The model number is required to get the correct manual.
The Model Number is on the motor tag.
It is in the format XXX . XXXXXX
Where X = a number.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Briggs & Stratton Garden
Craftsman 2500 PSI Briggs  Stratton Powered Pressure Washer Logo
1,328 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
