Question about Philips VR550 VHS VCR
Automatic recording? When I put a tape (any tape) in the machine it starts recording straight away without me touching anything, and the only way to stop it is to go to the machine and do so. The handset will not stop it when this happens. It also happens when i record something and then rewind. It does this then starts to record over again. Also there seems to be no 'Eject' button on the handset?
  • Bashstkid2 Apr 11, 2008
    I contacted Phillips about this problem, and they said take it back to the store, which I have just done. Thank you very much.
    Am I right in thinking there is no eject button on the handset of this machine?
  • 476 Answers
Check that the record button on the player is not pushed in. It could be the button stuck behind the casing, or the microswitch on the main circuit board stuck against the switch mech. This should be apparent, as there would be no click when you push the record button.
Also check the REC button on the remote control.
Both of these potentially could cause the symptoms you describe.
The remote control for the later VR series does not, as you say, have an eject button.There is no alternative unfortunately.
Posted on Apr 11, 2008
  • David Simpson Apr 11, 2008
    Further to my previous post, check that you have no timer recordings set. Also turn off "Direct Record" & "Record Link"
Toshiba vcr tape stuck after power outage
Do you have any small children who have access to the machine? Kids are notorious for posting coins, half eaten biscuits and bits of toys into the tape slot. 1st give the machine a light shake and see if it rattles, next remove it from any power source and remove the cover. You may find something obvious, if not, reconnect the power, being careful not to touch anything inside, and try to load a tape. Dirty heads WILL playback, but will NOT record. The standard for these machines is load spool to erase head, to video head, to soundhead, then between drive spindle and pinch roller and on to take up spool. Has the tape you are trying to record had the tab removed, if so (like a pre recorded tape) it will NOT record until you place a piece of tape securely over the tab hole.
Jun 21, 2014 | Toshiba Televison & Video
HOW I FIXMY VIVORT
Hi, This is a problem in the BIOS my advice to you is get in touch straight away as you will always have problems! unless they are prepared to walk you through the settings in the BIOS. Be a happy PC owner & get this exchanged free of everything they should exchange the PC without any problems & they will pick up the present PC when they deliver the new one to you. I must add the blue screen is another problem with the Video card, Hence stick out for an exchanged PC it's their liability. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 31, 2017 | ASUS VivoTab RT
VCR will not record
VHS tapes have little tabs on the side of them. They are located on the side pointing out when you put it into the VCR. If the tab is broken of it will not work to record anything. It tells the machine that the tape all ready has something on it. If you want to record over something you can usually put a little piece of paper in the hole of the missing tab and piece of tape over it you should be able to record.
Nov 18, 2013 | Quasar Televison & Video
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
Try to playback with other tape recorded earlier from other camera or VTR .If other tapes are palying properly without any glitches then it might be the problem with this recording.
anand
Oct 22, 2010 | Sony DSR-45 Mini DV VCR
Reel to reel tape payer
i changed the main drive belt on a reel to reel stereo tape recorder model no A1340 serial no 3642 there is a small wire arm under the play/ record head platform . I believe its the record switch . the arm is not straight looking at machine the arm is straight from switch and go at a 45 degree angle then turns straight and then angles up about a half inch or less . i need to know how to replace this arm ( switch) back into the the head platform so i can start using this recorder
do u have rhe service manual for this machine if so ca i get a copy ?
thanks
Arthur Hathaway
Nov 20, 2008 | Audio Players & Recorders
The video machine bleeps continually and shows a message E-3
I think the E3 error code indicates an error with the tape drive mechanism. If it ate a tape, this would indeed be the problem. Time Lapse VCR's are not very popular anymore, everything has gone to digital. It would most likely cost you more to fix that VCR than to switch out to a digital recorder.
Other advantages are -
No tape to change
Very good recorded image quality compared to VCR
Most digital units have capability for remote viewing over the internet
You can set the unit to "alert" you if there is movement in the garden
Sep 25, 2008 | Home Security
ERR symbol on VN-2100PC
I'm afraid that the only solution I can think of would be to put in a new set of batteries. If your quick about it, your might not lose the information.
Jun 10, 2008 | Olympus DS-4000 Digital Voice Recorder
Panasonic Video Recorder has stopped working
looks like some kind of sensor within the mechanical part, its seems like the mechanism doesnt return fully to its original point giving you these kind of malfunctions, I suggest to take it
to an authorized dealer for a complete check up & tune up
Apr 15, 2008 | Panasonic NV-HS1000 S-VHS VCR
Cannot Record using VHS
The question here would be one of two things. Obviously without probing further it would seem you're having an "unusual scheduled recording" issue. But, without further information it's difficult to tell.
For one, are you recording from straight signal (cable or antenna into the RF IN of the unit), or are you recording from a box (cable or satellite receiver or D/A converter, etc)?
Do your scheduled recordings record the first and not even pick-up the second, or do they record but only record static?
These are questions that will need to be answered before further assistance can be provided.
Feb 20, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't record
Unplug the VCR overnight, reset the clock and try the timer again. if that does not work, there is a fault in the microprocessor and you would need to get a new VCR I'm afraid, as the repair would cost you twice what a new VCR would. Good Luck
Jun 06, 2007 | Philips VR550 VHS VCR
Philips VR550 VHS VCR Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
