Question about Logitech Webcam
How to get your webcam working on msn messenger?
    Sergeant:
  • 195 Answers
If you press Alt+T it will bring up the tools menu, you can then go through the audio and video setup wizard from there.
Posted on Jun 02, 2010
Not working with msn messenger
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Apr 06, 2010 | Logitech QuickCam Messenger Web Camera
How to get labtec webcam to work on msn live?
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
this is the error msn i get when iam trying to use my camera in msn messenger on all other i can use ? whats the reason ?
Oct 09, 2009 | Xirlink Promax Webcam
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
When I try to talk to some one with the webcam on MSN Messenger I can see them but they can't see me. My webcam is just picking me up instead and not broadcasting to them.
try a different IM like yahoo messenger ..if it works...and it broadcasting ..it means that its something wrong with your msn messenger and need to reinstall it
Apr 09, 2009 | Logitech QuickCam Pro 5000 Webcam
My webcam works on msn messenger but not yahoo messenger. It is a HP webcam. Is there a compatibility issue? Should I change my webcam?
No there is no compatibility issue. But you cannot use cams simultaneously on 2 messenger. Make sure that when you using it in Yahoo messenger than msn is totally shut off. Try this it should help you.
If my advice helps you, than please feel free to rate me.
Thanks
Mar 22, 2009 | Logitech Webcam
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
When i am on msn and want to put on webcam a message appears in a conversation saying Messenger is not available right now. Please try again later. (0x8ac70202)
This might be a compatibility problem between your webcam drivers with the new Windows Live Messenger program. You may want to:
1. Update your webcam drivers and see if Windows Live Messenger can detect it when you run the Audio Video setup from its Tools menu.
2. Or you can downgrade back to the older version of Windows Live Messenger which is compatible for your camera. Doing this however also requires that you uninstall all the Windows Live Beta products from your computer.
Note: You will not see a separate Windows Live Messenger on your Add/Remove programs, instead you will either see there Windows Live Beta products or Windows Live Essentials.
You can download the older versions of Windows Live Messenger from:
Windows Live Messenger 8.1:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
Windows Live Messenger 8.5:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
~ Carlos
Nov 10, 2008 | Computers & Internet
Stingray 301
check only setting of msn messenger
>Its a problem of settings in msn messenger not problems of webcam
Dec 02, 2007 | Veo Stingray
Logitech Webcam Logo
24 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
