Question about Sony KP-51HW40 51" Rear Projection Television
My tv is staying in standby mood - Sony KP-51HW40 51" Rear Projection Television
  • 597 Answers
Count # of flashes , if any, call tech support.
Maybe power board
Posted on Jun 03, 2010
How do i stop my machine from staying in the dryer cycle and turn it back into wash mood
What controls when you are in the mood to wash, or in the mood to dry? Perhaps the weather, or it's related sounds?
May 12, 2017 | Washing Machines
Tv turns on but stays on standby
Have you checked the manual? Here is a link http://www.manualslib.com/manual/419601/Hitachi-42hds69-42-Plasma-Tv.html
May 15, 2016 | Hitachi 42HDS69 42 in. Plasma Television
Stays on standby no picture or sound
When a Sony TV has just the STANDBY LED lit and nothing is flashing (An error code) then the TV is in PC standby meaning usually that there is no signal coming in on the PC input (Computer). Turn on the computer that's attached to fix this. If this is incorrect then you will need to use your remote and select the correct tv signal input for your particular setup.
Good Luck!
Rich Lilja
Mar 23, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv stays on standby
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 25, 2012 | Orion TV 4200 42 in. Plasma TV
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
On then went off but power light is standby moode
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | Relisys TL 766 Monitor
My TV will turn on and stay on standby. You can
the video IC is broke so... buy a new and change it
Nov 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
When attempting to turn on the set, the standby light should blink for a a while then stop once the picture comes on. If a problem is detected internally, the standby light should blink in a repeated pattern. Please count the number of blinks that are repeating and we should be able to help.
Thanks,
Dan
Aug 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Sony KP-51HW40 51" Rear Projection Television Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
