No gas to any gas appliances , new gas bottle and regulator.
  • Dan Webster
    Dan Webster Jun 02, 2010
    What size tank?
  • Heating & Co... Master
  • 2,461 Answers
Could b eair in the line purge from union on gas line by appliances
Posted on Jun 03, 2010
Can i replace the jets on cookmaster cooker to work on bottle gas
Bottled gas reqires a different gas nipple, most new hopbs come with a set. Note that in the UK you need a gas safe qualified engineer to fit gas appliences to the mains. Not sure about bottled gas appliances.
Aug 23, 2016 | Kitchen Ranges
When I turn on the grill the gas flame does not go beyond about 1/3 of the way along the connector tube to the rear burner.
It could be a partially blocked gas jet or insufficient gas pressure is reaching the jet.
Clearly the pipes and valve should be checked if cleaning the jet doesn't provide a cure.
It is a good idea to compare the jet size and air bleed size with specifications. If it is set up for propane and being used with butane it will display the inefficiency you described.
There have been a few appliances designed for use with bottled gas that weren't intended to be used with a pressure regulator and lots of propane appliances that need a higher pressure than the standard fixed regulator can supply and an adjustable regulator should be used instead.
Sep 04, 2015 | Weber Genesis Silver B Grill
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
New gas bottle, do regulators go bad? bottle and burners on
some times they do , remove bottle from line open gas burners let off gas in line , reconnect bottle turn on slow then light burners see if you have more flame.
Sep 24, 2011 | Weber E-210 Grill
I can light the pilot light ok but when i turn the knob up it blows the pilot light out again. The cooker that runs off the same gas bottle does not seem to be getting enough gas through either.
From what you have described, it sounds like a gas pressure problem, which may be related to the gas bottle's regulator. Or you are running out of gas and there is not enough to sustain both gas appliances. And finally, there may be an obstruction somewhere in the gas line. Even a kink in the gas line could cause it. These are the things you need to troubleshoot first.
Hope this helps you solve the problem.
Mar 21, 2011 | Heating & Cooling
Flames are coming from the top of heater bricks. Thought pressure was to high so changed regulator on gas bottle but to no avail..! What else could it be ?
haven't had any time with delonghi heaters but usually the gas pressure can be controlled at heater by the valve they usually have hi/low adjustments on them there usually is a screw that is covering this adjustment and you must use your manommater to set heater to its high kpa rating (usually a slight adjustment under its hi setting is better to set too), changing the regulator will only change the supply gas to heater not the burning pressure which is done at valve in heater and most heaters regulate there own pressure so be careful using regulators they can drop the pressure to much to a heater and not let enough gas pressure through to heater so it can run at its full efficiency i have seen this done on a commercial job when comissioning heater could not get more than .5Kpa on .8Kpa natural gas appliance, your appliance L.P.G so pressure will be higher on hi setting but i'm guessing should be set at valve in heater or you could just have a faulty valve in appliance if you can't set valve
Nov 19, 2010 | DeLonghi Heating & Cooling
Grill is one old and won't light. There is no gas coming from the tank to the grill. Is it the regulator?
age of the grill is irrelevant, i am old and i still can do few thingzzzz...
i assume that your regulator is connected directly to the bottle, then hose to your bottle, then hose is connected to the regulator and other end to the grill?
or it is bottle, hose, regulator, grill?
you need to follow the path regardless, be outside, light breeze is better, no open flame in at least 20m (yards) radius in any direction.
1. close gas bottle/tank
2. disconnect, everything from the bottle
3. crack open tank valve and hear if gas is escaping, close valve back
4. connect regulator to the bottle and again crack open the valve, hear if you have esacping gas, allow actually whiff of gas against your cheek or wetted finger to establish the flow. close the valve
5. connect hose to the regulator (procedure is reversed if first is hose and then regulator), crack open the valve, hear for escaping gas, check against wetted finger and cheek if there is flow, close the valve
6. connect your grill open all valves on it and open valve on the tank/bottle. allow free flow for about 30sec, close valves on grill. vent grill for about two minutes, try to ignite any of the burners. if burner ignite, you solved the problem, if they do not, and you did have flow on all previous stages, close bottle valve, disconnect everything from grill, clean grill valves and nozzles (burner have nozzle inside!), reconnect and vent again, try ignite, if ignition occures, you solve the problem, if not, then you are due for new grill...
if at any stage you do not have gas flow, this meant that this particular piece of equipment is in trouble, this particular piece of equipment need then repair or replacement, under no circumstance pull apart the reducer! NO OPEN FLAME DURING TESTING!!!
Jul 27, 2010 | Weber Q Grill
Sears gas grill
If it was me I would return it. You did the right thing by testing it on another grill. You should not have to accept a new grill that is not working properly.
Loringh
Nov 04, 2008 | Grilling
No gas is getting to the burners. It was working and suddenly quit. I changed the bottle to a new bottle. No gas. I ran a thin wire through the regulator. No gas. There are three burner valves - none...
This problem sounds like the internal vent in the regulator has clogged up and will not change state to let the valve inside open. You can purchase the regulator from most hardware chain stores or directly from the manufacturer.
Hope this helps you out.
Jun 18, 2008 | Weber Genesis Silver B Grill
Gas grill regulator freezing
I do not understand the term " regulator and gas line from the regulator ice up" Do you mean ice up as in frozen water? I do not know where the water would come from. Is there a drip leg on your gas piping? A drip leg is pipe nipple placed before the appliance.
fireguy
Apr 14, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
