Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
I have a motorola bluetooth without the pairing code. Also I can not tell by looking at it what model it is ...it just says Motorola. it was my fathers and he can not find the book. Help I need it for work and can't make it work.
    President:
  • 1,118 Answers
Bluetooth headsets have their pairing code hardcoded by their manufacturers. Most of them, choose '0000' (four zeros). Others choose '1234', whilst some of them use '8888'.
A bluetooth headset must be put in pairing mode, prior to its first connection to a bluetooth enabled device (e.g. phone, PC). All of them must be turned off before starting the pairing procedure. Some motorola headsets have a boom, which must be opened, in order for it to enter the pairing mode, whilst other headstets must have their Multi Function Button (MFB, or Call/End button) pressed and held for some 6 to 10 seconds. Their LED light use to indicate their pairing mode. Some of them flash rapidly (sometimes in more than one color), whilst others keep it solidly lit. Anyway, once your headset is in pairing mode, make your phone (or PC)'s bluetooth application search for new devices. After a while, your headset should appear on the device' screen. Select it and make the application connect. If a passkey (or PIN, or pairing code) is requested one of the codes I've suggested above.
The pairing procedure, between any two bluetooth enabled devices, should be done only once. All subsequent connections should be achieved by bring both devices, with their bluetooth radio turned on, close enough to each other. If their link is not automatically established, a simple press on the headset's MFB should be enough.
Hope you are able to pair your headset soon.
Regards, Carlos
Posted on Jun 02, 2010
Pairing code for my sanyo HDTV integrated model to my cell phone a Motorola smartphone I believe??!!
Debra
Check with Sanyo. You typically have to enter on your phone the code from the other Bluetooth device. Never heard of a TV having Bluetooth. What model TV is it?
Mark
Motorola Support
Aug 11, 2015 | Motorola Cell Phones
I juat want to ask the passkey for motorola h505
i recently activated and paired my motorola bluetooth headset to my blackberry 9650. I found online a motorola page through a search which had a support section in which was an illustrated guide for pairing headset to handset, which was extremely helpful. However neither phone nor headset had a correct model number listed, so I choose similar a handset and headset to use for the illistrated support. After turning on the bluetooth, making sure it is discoverable (which should be the default setting on your bluetooth since there is no screen or buttons for you to change things besides on/off and volume), and pairing the two, the phone asks for a pass code for the headset. Now as i said in the beginning you have to choose a certain model handset and headset, so in the illustration they give you pass code for the specific headset, however my headset was not listed. I have a motorola bluetooth model number h505 and i choose model number h520. The pass code given for the h520 was 0000, which worked for my h505. I just went back to the site and there is an option for passkeys (passkey, pass code, and pairing code are all the same thing). If you have motorola, the code is either 1234, or 0000 (four zeros). This is the link directly to the motorola support site, I hope this novel I just wrote helps, good luck. https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/21216/p_country_code/US
Jan 01, 2011 | Cell Phones
I have lost my paired code for my motorola H3 headset
The paired code for the motorola h3 bluetooth headset is set to 0000 by default. I don't think there is a way to change it so your code should still be 0000.
Jul 02, 2010 | Motorola Mobility H3 Bluetooth Headset,...
I am unable to pair my motorola blue tooth with my LG Wine
You must enter the default Bluetooth pairing code, on your phone, when prompted. The code is 0000 (four zeros).
For your reference, the brand of a Bluetooth device has nothing to do with compatibility. Bluetooth Corporation licenses its technology to many other companies. Devices using Bluetooth technology must conform to the Bluetooth standards. So, a Motorola Bluetooth device will definitely pair with your LG phone, or any other brand of phone supporting Bluetooth device communication.
Jan 25, 2010 | OEM Systems Bluetooth Headsets - Model...
Code for bluetooth car kit
Also note that some of the IHF1000 carkits may also use 1234 for the passcode. When you go into the Setup Menu and ask it to Pair a Phone, the prompt will tell you the correct passcode (0000 or 1234) to enter by saying, "Enter xxxx, when requested".
Nov 24, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Code doesn't work!
space.gif I took this off Motorolas website. question.gif What's the pairing pin code and can I change it?
space.gif space.gif answer.gif The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
Are you holding the button on the bluetooth till it turns purple. If not then it wont sync properly. After the Bluetooth turns purple then go to your phone and have the phone look for devices. Check this wbsite for pairing instructions
http://www.motorola.com/mdirect/demos/how2_h700/main.html
Jul 22, 2008 | Motorola Mobility H700 Wireless Headset
Pairing bluetooth with new phone
You have to hold the on button until it is a solid blue light not flashing 5 or 6 seconds then it is ready to be paired.
Jun 21, 2008 | Motorola Mobility H300 Wireless Headset
Bluetooth H500
when it asked for the pincode to paired the bluetooth headset enter the code 0000
Jan 02, 2008 | Motorola Mobility RAZR V3
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
483 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
