Question about Imperial ICVD-1 Turbo-Flow Electric Single Oven
Imperial EBJ 1852 shows '-' on temperatur display even when off, and does not stop heating on selected temperatur
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
Bottom element is not heating to temp an shuts off during heat up - without error code showing in the display. IE. - Press Bake, 350 degrees defaults on screen; Press Start. YOu hear the Click as it...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | GE JTP15 Electric Single Oven
Light pilot for oven
IF IT HAS A STANDING PIOLOT YOU SHOULD CHECK YOUR BOOK ON HOW TO LIGHT.IF YOU DONT HAVE A BOOK SOME IF THE IMPERIAL STOVES YOU HAVE TO HOLD IN THE TEMPERATURE KNOB IN THEN LIGHT IT. HOLD THE KNOB IN FOR A MINEUTE THEN IT SHOULD STAY ON.REMEMBER GAS IS DANGEROUSE,IF YOU SMELL IT YOU SHOULD STOP AND LET IT AIR OUT.GOOD LUCK BE SAFE
ERIC
Jan 21, 2010 | Imperial Ovens
Oven self-clean won't turn off!!
You will need to press the stop/cancel button, this will clear the cleaning cycle, due to the interruption. If this does not clear the display you will need to unplug the stove for five minutes and then plug it back in and this should clear the display.
Nov 14, 2009 | GE Ovens
My Frigidaire electronic single wall oven FEB275ASB won't stop beeping. It displays a P4 error
F4 Shorted oven sensor (RTD) Check for shorted wiring between EOC and RTD. Check resistance of RTD using resistance table. If resistance test is correct and wiring is good replace EOC TEMPERATURE °F RESISTANCE ω 32 ± 1.9 1000 ± 4.0 75 ± 2.5 1091 ± 5.3 250 ± 4.4 1453 ± 8.9 350 ± 5.4 1654 ± 10.8 450 ± 6.9 1852 ± 13.5 550 ± 8.2 2047 ± 15.8 650 ± 13.6 2237 ± 18.5 900 ± 13.6 2697 ± 24.4
Sep 20, 2009 | Frigidaire FEB27S5A Electric Single Oven
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Imperial oven
No not really. If you can see the burners, do they go off completely because they should. If not, maybe a faulty gas valve.
Mar 31, 2008 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
Feb 13, 2008 | Thermador C272 Electric Double Oven
Imperial ICVD-1 Turbo-Flow Electric Single Oven Logo
54 people viewed this question
Top Imperial Ovens Experts
Dan Webster
Dan Webster
Dennis Boxerman
D. E. Hev
Are you an Imperial Oven Expert? Answer questions, earn points and help others
