Question about Hunter (25417) Ceiling Fan
Fan operation When the fan is operating the blades turn counter clockwise, can this be reversed
  • 34 Answers
Use the slide switch on the switch housing. In rare case, it may be on the motor.
Posted on Sep 09, 2010
Pulls air in (clockwise) only, have tried reversing, won't pull air out (counter-clockwise)
fan blades are designed to move air in one direction only
if you want a unit to reverse the air flow then reverse the installation of the whole unit or get the correct unit for the job
May 02, 2015 | FAN-TASTIC VENT Fantastic 6000rbta 12 volt...
Altura 68'' ceiling fan only operates counter clock wise. Removed remote control function. Operates by 3 speed wall switch. How do I operate the fan in the clock wise position. Installed in 2010. It just...
If there's no reverse switch on the fan you won't be able to unless you put the remote back. Also, It should be going counter clockwise.
Aug 09, 2014 | Dryers
Why does my kubota lawn mower die when i mow in reverse even when i push the button?
Check the blade housing and any build up of waste which can cause too much tension on the blades when they are operating as the unit moves in reverse. The rotor head could could be jamming. With the unit turned OFF try to move the blades clockwise and counter clockwise. There should be equal force required to move the blades in either direction. If not then clear and clean all the area and especially where the spindle comes through the body from the engine. Oil and regrease all required points.
Jul 22, 2014 | Kubota Garden
How do I change the blade on a skilsaw 5250 2 1/4 hp 7 1/4 in. circular saw... there is no "locking mechanism" on this model? is this a "left-handed" bolt, Do I turn it...
Here is what you do, this is common on some skill saws, you of course make sure is unplugged, get your self a stick ( like a small broom handle type, or a piece of 1 by 2 chuck or wood, or anything of about that size. Put saw on its side, with the blade side toward you to get access to the nut to take off blade. As you know the blades go down( clockwise when operating to cut wood) and of course now, you have the problem of taking off the blade counter clockwise because the angle of the blades are going back words, ( nothing to grab on to the wood, to put a wrench on going counter clock wise to take nut off. What the idea for you and normal way is this, as the saw is on the side, with the nut/blade side toward you, you wedge the piece of wood, between the left top side of blade under the frame of the blade, meaning you are wedging it in, so the blade when turning the nut counter clockwise to unscrew, will stay in place. Think of it as wedging the blade with a chunk of wood, so it will not move. AGAIN, it comes off (nut) counter clockwise, so, you are just using this wood chunk to keep blade from moving, and then to put new blade on, just reverse procedure. Thanks Mike
Jul 26, 2011 | Garden
Does the bolt on the blade come off counterclockwise or clockwise.
If you are facing the blade from where the bolt is, and the blade's normal operation is to turn counter-clockwise, then the bolt will loosen counter-clockwise. This is universally true for any blade which is held on by a center bolt (table saws, grinders, etc.) This is because the motor is turning the shaft counter-clockwise, and the resistance against the blade as it does it's work is clockwise - thus tightening the blade rather than loosening it. If the blade normally turns clockwise, then the bolt will loosen clockwise.
Jun 24, 2010 | Craftsman Garden
Fan goes in reverse instead of pushing air down it goes counter clockwise. How do i reverse it?
1.) this model uses a remote control controller to operate its functions
2.) the reversing is done via that remote.
3.) the link is wireless
4.) do you have the remote?
Apr 28, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
U line ice maker on boat
If this is a stand alone icemaker. Is the unit running? If not check the icemaker ejector blades to make sure that its pointing at 12 oclock. If not then you need to take the cover off the icemaker and turn the smaller gear counter clockwise.(remove cover by gently prying on the inside corners and pull at the same time) Turning it counter clockwise will turn the ejector blade. Once you get it to 12 the plug the unit in and turn on. Compressor and fan should come on. If the unit is running then make sure the fan is operating. Yes then is the compressor on? Yes > then you have a sealed system problem. Let me know if you need further assistance.
Jun 17, 2009 | U-Line Icemaker
How do I reverse the direction of the fan blades to counter-clockwise on the fan? The fan is a Hampton Bay ''Clarington'' with a remote control.
There is a small black switch on the switch housing directly under the blades. When the fan is completely off, move the switch to the opposite direction.
Mar 31, 2009 | Universal Remote Control Hampton Bay...
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Hunter (25417) Ceiling Fan Logo
54 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
