Question about Hummingbird Exceed 10.0
I need the wiring diagram of the model TCR101 fishfinder
I have lost my wiring diagram and need to connect my fishfinder.
please help
    Sergeant:
  • 269 Answers
Garman or hummingbird?
mel
Posted on Jun 02, 2010
Garmin fishfinder 160c sonar failure
Hi Lakshmaan:
The first thing I would check would be the electrical connections from the transducer, and the transducer wire.
Jun 07, 2016 | Garmin Color Fishfinder 160c
The diagram for the fish finder has two cables for power. does each cable have a wire going to a hot lead and a groundand a bond or do you just need to connect only one wire
Hi
One of the two cables is for power to the battery while the other supplies power to the transducer. BOTH cables (+ and -) must be used and intact.
In case anyone requires it, here is the link to the installation manual.
Hope this helps.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GB/ELITE-4_HDI_OM_EN_988-10576-001_w.pdf
Feb 28, 2015 | Lowrance Elite-4x Fishfinder
Hello! I have NAVMAN 4150sx fishfinder and I need wiring diagram for that fishfinder. Erkki
Here is the link to the owners manual.It has a copy of a wiring diagram.Not sure if it is the one you are looking for but maybe someone else may be able to use it if not. Hope this helps you with your project
Good Luck
http://www.navmanmarine.net/upload/marine/internet_manuals/eol/4100_4150_eng_web.pdf
Dec 09, 2014 | Fishing
Whirlpool wiring diagrams
Need to be more specific on unit. Model, Serial Number. Should be inside the door!
Nov 13, 2017 | Dryers
Try
www.manualslib.com
Dec 01, 2017 | Dryers
Connections problem
Question: What are the extra wires used for on the power cable for my fishfinder?
I found this on the carmin website under questions and answers. I think your cable is ok to use according to this.
--> Answer: Not all of the wires in the harness are required for use. To connect the unit to the power source, only the black & red wires are required (black to ground, red to positive). Here are descriptions of the other wires in the harness:
  • The Blue wire is used for a NMEA data out connection to another NMEA compatible device. The fish finder outputs NMEA 0183 version 3.01. The receiving device must be compatible with this format and looking for the NEMA sentences DPT, DBT, MTM, or VHW.
  • The Brown wire is used for a NMEA data in connection to receive data from another NMEA compatible device.
  • The Yellow wire is used to connect to an external buzzer or alarm to alert you to any alarms which have been set to sound on the device. The Yellow GARMIN wire connects to the negative end of the external alarm. The positive return on the alarm will connect to the red positive wire of GARMIN.
  • The green, white, and any other colors present have no connection purpose related to your fishfinder. The 18 Pin connector wiring harness is used by several other devices which utilize these wires.
If the device is only being connected to power & do not require a NMEA interface, PC connection, or external alarm support, only the red & black wires are required.
Jul 05, 2012 | Garmin Fishfinder 90
My Fishfinder 300C suddeny does not detect the depht anymore, all oher function are still working, please help!
Hello
First do this. From the Home screen, Seelct Full Screen > Menu > range. Use ROCKER to set the depth scale, and see whether the depth is displayed or not. If not check the transducer for fault. Check for voltage goint to it.
Use a test light or voltmeter to determine the polarity of the voltage source.
Connect the red (+ or positive) wire to the positive voltage terminal.
If you use the fuse block on the boat, route the positive connection
through the fuse
Connect the black (- or ground) wire to the negative voltage terminal.
Install or check the 3A fuse (on the fuse block or in the in-line holder).
Align the notches on the cable plug and on the back of the Fishfinder 300C. Insert the cable into the connector, and turn the locking ring
counter-clockwise until it stops.
If htese all are correct and voltage is there at the tranducer end, the tranducer is faulty, and should be replaced. OK
Jul 25, 2011 | GPS
Searching for wiring diagram
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
May 20, 2008 | Computers & Internet
Hummingbird Exceed 10.0 Logo
181 people viewed this question
Top Hummingbird Computers & Internet Experts
Les Morrison
Les Morrison
Andrew Taylor
Andrew Taylor
Are you a Hummingbird Computer and Internet Expert? Answer questions, earn points and help others
