Question about Microsoft Windows Vista Home Premium Edition for PC
Missing task bar - running vista - Microsoft Windows Vista Home Premium Edition for PC
    Novelist:
  • 112 Answers
Your taskbar may be hidden. You can try moving your mouse pointer to the edge of the screen where the taskbar usually is and see if it appears. If not, you can try the following fixes:
Fix 1:
1. Right click on your desktop and select Personalize.
2. In the lower left side of the window it says "See Also". There should be a link called "Taskbar and Start Menu". Click that link.
3. Check/select the box next to the option that says "Auto-Hide the taskbar"
4. Hit the "Apply" button at the bottom and then uncheck/deselect the "Auto-Hide the taskbar" option and hit apply again.
If the "Auto-Hide the taskbar" option is already checked when you first go into the "Taskbar and Start Menu" options, use the same procedure listed above, except you will uncheck the box, hit apply, and if the taskbar does not appear, check the box, hit apply, then uncheck the box and hit apply again. If this does not work, try the next solution below.
Fix 2:
Press CTRL+SHIFT+ESC at the same time to bring up your Task Manager. At the top of the task manager window click on "File" then a menu will drop down and in that menu, click on "New Task" and a box will open up. In that box type explorer or explorer.exe and then click the "OK" button at the bottom. If your taskbar still does not appear, try the next fix.
Fix 3:
Insert your Windows Vista Installation CD/DVD into your CD/DVD drive and reboot the computer. During the bootup screen, it should say "Press any key to boot from CD". Press a key to boot from the CD and when it boots to the windows installation screen, select the "Repair" option and NOT the "Install Windows" option. That will bring you to a repair screen where you can run startup repair. It will perform tests and attempt to fix any problems with your Windows Vista. If that doesn't work, you will see the option to do a system restore. Select a restore point from a point in time when your computer was working properly, or just use the one that Windows automatically selects then do a system restore. Once the system restore is finished, reboot your computer, remove the Windows Installation Disc from the drive, and let your computer boot. Your issue should be resolved.
I hope this helps! If so, please leave me a rating and feedback. I would greatly appreciate it!
Best Regards,
James Trageser
Posted on Jun 02, 2010
  • 53 Answers
Sounds like explorer.exe is not running:
1. Hit Ctrl + Shift + Esc at same time.
2. Windows Task Manager should open.
3. Hit File on top menu.
4. Select New Task.
5. Type explorer.exe and hit OK
That should bring your task bar back.
How to Check Windows Memory?
Windows 7/Vista:
  1. To check current Memory usage on a Windows 7/Vista computer, right click on Task Bar (Task Bar is the Grey/Blue bar at the bottom of the screen) then left click on "Start Task Manager". You will see "Windows Task Manager" window. ...
  2. Click on "Performance" tab within "Windows Task Manager
Oct 19, 2016 | Computers & Internet
How do I find out what programs are running on my dell 531 with vista os
To find out what programs are running on a vista operating system you can hold the key combination
CTRL + ALT + Delete
Then select 'Start Task Manager'
an alternative method is to Right-Click in an empty portion of the start bar and select 'Task Manager'
In the applications Tab you will be able to see all the programs running at the time. Under the Processes tab you can see what processes the applications are running under.
Aug 08, 2013 | Dell Inspiron Computers & Internet
My laptop is HP Compaq 6720s Volume, Power, and Network notification icons are missing from taskbar. They cannot be re-enabled from the Taskbar and Start Menu Properties as they are disabled or grayed out....
This is a simple fix in windows vista or windows 7. hit the keys CTRL+ALT+DELETE simultaneously and release. The screen that comes up click on Start Task Manager.
In the task manager window click on Processes Tab. Look for explorer.exe and highlight it and click End Process. Click Yes to stop it. When it is gone from the list, click the Applications tab and click on New Task. In the run box that pops up, type in explorer.exe and click OK or hit Enter. Once your task bar and icons repair look in the system tray area by the clock and the missing icons should now be there.
Apr 14, 2011 | HP Compaq 6720s Notebook
I'm trying to install Printshop Zoom made for Vista/XP to my Windows 7 laptop -- it won't load properly after installation and tells me some of the files are missing and I need to run repair. I ran it 3...
Do you have a repair program? Like Macphee for example. These programs should be located on your task bar at the bottom right of monitor. The arrow pointing up is where these programs are located.
Nov 18, 2010 | Computers & Internet
Virtual PC 2007 does not open in Vista Ultimate 64-bit OS
right click>> setting(or propertis) run with this mode>> XP set.
Feb 15, 2010 | Microsoft Virtual PC for PC
The sound icon is no longer on the task bar. I can't control the sound.
Click Start
Click Control Panel
Click Classic View
Click Sounds and Audio Devices
Click Place Sound Icon on the Task Bar
(so that the check-mark is removed)
Click Apply
(so that the check-mark is restored)
Click OK
Done.
Oct 29, 2009 | Microsoft Windows Vista Home Premium with...
Task bar is missing on bottom of screen after pc wakes up.
mine does this with windows 7, right click on desktop and open 'personalize' then open 'taskbar and start menu'
From here choose to move your taskbar location to the side of the screen and click apply. it should return, then just tell it to go back to the bottom.
Sep 18, 2009 | Dell Studio XPS 435 PC Desktop
Tool bar missing on computer
Assuming "tool bar" = Task bar
and your OS = XP
It's possible your task bar is hidden on bottom
just drag the bottom line of your screen upward
Check if your task bar properties are set to "hide the task bar" remove the setting
Jan 05, 2009 | HP Pavilion dv6000z Notebook
Uxtheme.dll is missing
You can download missing DLL from here
if windows explorer dont start use task manager-> run to copy missing DLL
Dec 24, 2008 | Microsoft Windows Vista Ultimate Edition
Windows vista home premium taskbar troubleshooting
dear sir
please click on the task bar drag it & drop it on the bottom of the desktop
regards
murali
Dec 18, 2008 | Microsoft Windows Vista Home Premium with...
Microsoft Windows Vista Home Premium Edition for PC Logo
144 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
