Question about Gateway Wireless-B Router (wbr-100)
What is the security Key I am trying to set up my wireless connection but can not find Wireless Network Name (SSID) or Wireless Encryption Key:
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
You can also find SSID to set network name in wireless settings.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 02, 2010
Where do I fine SSID Name & Encryption Key
If you are trying to set up a router and need to establish the SSID name and WPA encryption key, you will need to sign into the router using the routers IP address. Input the userid and password, then go to the wireless network setup page. Here is where you enable wireless operation, establish the SSID, and generate the encryption key or passphrase.
If you are trying to connect to someone else's wireless network, you need to know their SSID so that when you do a search for available networks you can determine which is theirs. Once that is established, if they give you the encryption key or passphrase, you can attempt to connect to their network. With the encryption key or passphrase, you will not be able to connect.
Mar 15, 2015 | Motorola Computers & Internet
Coda qoy
Sir
Checking or verifying the wireless settings of your Linksys Cable Gateway is important when connecting wireless devices to your network. This is the best route to take if you are unsure of your gateway's wireless settings.
The wireless settings that you need to take note of are:
  • SSID
  • SSID Broadcast
  • Wireless Security
To check the wireless settings on the Linksys gateway follow the steps below:
Step 1:
Access the gateway's web-based setup page. For instructions, click here. If you are using a Maccomputer to access the cable gateway's web-based setup page, click here.
Step 2:
Click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID). It is recommended to change the SSID to something unique.
Step 4:
Click the Wireless Security sub-tab and take note of the current Wireless Encryption Level and the Wireless SSID Broadcast if it is set to Enable or Disable.
If Wireless Encryption Level is set to No Encryption, this means that the wireless security on the gateway is disabled.
If Wireless Encryption Level is set to 64 Bit Encryption or 128 Bit Encryption, check the value under Default Key and take note of the Wireless WEP Key that corresponds to it.
I hope Your problem is Linksys router Problem is solved by now, In case You still need Linksys Router Help Then I Suggest you follow official Linksys Router Support URL Website mention below :
Linksys Support
Or
In case You still need online Linksys Router Support Then follow us On for Linksys Router Support
Mar 27, 2014 | Linksys WCG200 Router
What is my SSID #
The SSID is the router's wireless network name.
Network security key
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Apr 27, 2012 | Westell Wirespeed Computers & Internet
I need a network key to confirm and do not have one HELP
Your wireless card in your computer or laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 29, 2010 | D-Link DIR-300 Wireless Router
We are trying to secure our internet but are not sure which number to use off of the rouder when it asks for the pin #.
Your wireless card in her laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (pin or security key) is in your wireless router, without this key the wireless router won't allow the laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
Dec 29, 2010 | Linksys WRT110 Wireless Router
I own a belkin n150 router. i've used ti on my laptop and now i bought a another computer and it won't let me access my router. it is asking for a security key. any idea how to access it or find it?
The encryption key (security key) is in your wireless router, without this key the wireless router won't allow the laptop to connect to this wireless router.
Dec 29, 2010 | Belkin N150 Enhanced Wireless Router...
I need to secure my router. I had payed to have it set up when I was getting my computer fixed only to find out that my son could log on with out a password. How can I fix this.
To set up wireless router security, there are four main steps, which are the same for most routers. These are:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
4) Enable WPA encryption.
************DETAILS************
1) Login to your router, using a wired (Ethernet) connection.
Make sure you have a cabled connection to your router. Then open a web browser, and type the router’s IP address into the address bar. For example, this is http://192.168.0.1
If you log in successfully, you should then see the router configuration screen.
2) Change the router login password.
To change the router password, find a menu option such as Setup, Tools, Administration, Basic Settings, Management, or Utilities.
Set and confirm a new login password. Click ‘Save/Apply’ when finished.
3) Change the SSID (network name):
The SSID or Network Name is the name you see when you are looking for an ‘available wireless network’.
To access this setting, find a menu option such as Wireless, Wireless Security, Security, or perhaps Advanced Settings.
Change the SSID from the default, to anything you like. It is case sensitive, and you can use up to 32 letters – but do not use something that could identify you, or your location. Click ‘Save’ or ‘Apply’ when finished.
Find the Wireless Security or Wireless Encryption Options section - often in the same section as the SSID (eg for Netgear – it’s still in Wireless Settings).
You may have a number of encryption options. Select WPA-PSK or WPA2-PSK (good choices to start with).
You then need to enter a network key. The box to enter this may be labelled Network Key: it may also be labelled WPA-PSK, WPA Shared Key, PSK, Security key, Passphrase, Pre-shared key, Authentication key .
Note down your network key carefully. You will need this to connect wirelessly. Click ‘Apply/Save’ when finished.
That's it - you have done enough to secure your network, and can close the screen.
Apr 08, 2009 | SMC Barricade 7004VWBR Wireless Router
I have a linskys wireless G access point. Its working for my laptop but just recently my laptop said that my interent secuirty is secuirty enabled and that linkys is a unsecure network. What do I do? It...
jpconda - you did nothing wrong.
By changing your SSID, your connection broke, because you were still associated with your old SSID (linksys).
Right-click on your wireless network connection symbol in your taskbar and choose "View Available Wireless Networks". If you broadcast your SSID, you should see your new name in the list.
Just connect to it (and hopefully enter the security key..;-).
If you don't see it, go to 192.168.1.1 and enable the broadcast of your SSID ( on the Wireless Tab - Basic Wireless Settings). Don't forget to save your changes!
Once your are connected, you can disable the broadcast again, if you don't want someone else to "see" your network.
Jan 11, 2009 | Linksys Wireless-G WRT54G Router
How do I install linksys router
Hi there, and welcome to FixYa
Connect the pc with a cable to any of the four LAN connections on the back of the router.
DO SET THE ADMIN password as the first thing you do.
goto -> administration -> management, fill out the router password and reenter it to confirm.
Give your network a name (SSID) so that you can find yours if there is more around you. Network name are called SSID, short for service set identifier
goto -> wireless -> basic wireless settingsWireless Network Mode : set to mixed,
Wireless Network Name (SSID), set a name well known to you, NOT your address :-)
now set the  Wireless Channel :  to any other than channel 6, which is the one everybody use. Too much electrical noise might interfere with your transmitting.
Now, go to Wireless -> Wireless connection, to set the Encryption security settings.
Set security mode to WEP,
Set the Transmit key to your choice, if you know that you wireless card has 4 keys as well, I would use key 4.
Set WEP encryption to: 128 bit 26 hex digits.
Go down to key 4, and find combination of numbers and the letters a, b, c, d, e or f.
(ex. 414243444546474849404a4b4c) = 26 hex digits.
Save settings.
Now, before you leave, WRITE DOWN your SSID, your password and key 4 with your settings, as you need to set your wireless card with the same settings.
Start -> settings -> network and right click your wireless connection and click properties.
At the top, choose Wireless network, find your network, (your SSID) choose properties and set these settings as you wrote down from the router.
Now, remove the cable and logon wireless.
/Teis
Do let me know how you are getting along.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Having trouble adding computer to wireless network
this is just easy.. what you should type is the encryption key only... if your security is wep, only the encryption key or key 1 is needed. if your security is wpa, only the passphrase is needed.. it is very CASE SENSITIVE.. but if you see that the name has changed to LINKYS_SES, then you have a problem there because your wireless settings has changed due to the button on your router which is the secure easy set-up on the upper left corner which is the cisco button.
Feb 21, 2008 | Linksys Wireless-G WRT54GS Router...
Gateway Wireless-B Router (wbr-100) Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
