Question about Homelite Mighty Lite Lawn Trimmer
Ryobi strimmer petrol strimmer stalls on rev up can you solve this problem
I can not take the cover off to put the line back in
Posted on Oct 02, 2010
Hi what is the ratio of oil to petrol on the 26cc petrol strimmer
Usually on a 2 cycle engine I will use 32-1 mix. Most engines will be fine if you get a name brand oil like Ryobi, Still, Echo, etc, with a pre-measure area made on top of the bottle. Follow instructions (usually 2.6 ounces per gallon.)
Feb 25, 2015 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
Ryobi strimmer petrol wont start
check spark plug. hT lead.
Jun 30, 2010 | Ryobi Garden
My Ryobi PLT 2543 strimmer will run, but cuts out when the throttle is opened
I had this problem twice in the past. I solved it the first time by replacingthe plug and setting the plug gap with a feeler guage. The next time it was a decoke of the cylinder (squirting through the plug hole) replacing the plug and leaving it overnight and then cleaning the air filter. It runs like a dream and has worked in Australia, Europe and the UK with no further problems. Also the fule mix has to be just right, I actually use 22:1 instead of 25:1 and do not use any petrol / gas with additives in (like Shell).
Aug 29, 2009 | Ryobi Garden
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a rhobi strimmer only 2 years old wont start
I presume this is a petrol one. The fuel can dry in the carby and stop the unit from starting. Use fresh petrol.
I am not sure about the ryoby unit, but if there is a air filter, take it out and dip it in petrol, then try to start with the normal proceedure in the manual.
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi petrol strimmer model RCT 2800 refuses to start
Has anyone got a spare cord Pulley for a Ryobi RCT 2800C . The engine seized but I have freed it and now see the plastic spines are damaged on the pulley. I understand the part no is Hayter 683856.
Nov 07, 2008 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
529 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
