Question about Boating
I have a Humminbird TCR 101 fishfinder which was installed on my boat. My boat got stolen so I lost the bracket and wiring. I am looking for the wiring diagram. Please help if possible. Thank You Danny Elmont
  • 20 Answers
SOURCE: Humminbird Matrix 67GPS -fishing system
Try this manual:
www.humminbird.com/PDF/M67.pdf
Posted on Jan 29, 2008
Benimur
  • 6966 Answers
SOURCE: Humminbird fishfinder keeps blowing 5v
Most probable component that has gone bad and capable of blowing the 5V fuse would be:
  • voltage regulator IV or transistor;
  • reverse protection diode;
  • zener diode;
  • shorted capacitor.
As the 5VDC normally supplies the logic circuitry, perhaps diagnosis and tests should be focused within that area.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 24, 2008
ward_knutson
  • 64 Answers
SOURCE: go about getting operational anual for fish finder humminbird
I found what you are looking for. Go to: http://www.humminbird.com/support/FAQ.aspx?faqid=72
You can download the operating manual.
Posted on Nov 26, 2008
captainjeffq
  • 52 Answers
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Posted on Apr 14, 2009
  • 58 Answers
SOURCE: wireing 2 12volt batteries into boat via isolatorswitch
hi put your 2 batteries in parallel with an isolator switch on both negative wires and another switch on the negative wire that joins the 2 batteries this way you can run on either battery and charge that battery or with the isolator between the batteries switched on charge both at the same time if you carn't understand it send me an e mail at chrisdoughty@sky.com and i will draw it hope this helps merlin v 12
Posted on Aug 29, 2009
Gps problem
If the new harness / parts are listed for use with this model GPS, it should work - unless you have miswired something. Double-check your work. Make sure all connections are made up tight. Pay particular attention to the ground wire. Relying on the boat to pass ground it not reliable. Look for damaged or cut cable from power source and transducer. You may wish to troubleshoot with a meter or a test light to be sure power is available at the GPS. Good luck!
May 29, 2013 | Humminbird 1198C SI Side Imaging High...
I need a longer power cable for my humminbird 561, is it possible
don't splice them bad bad bad call hummingbird order you a set of power cables
Apr 11, 2013 | Humminbird 561 Fishfinder
How to install transducer
Transducers usually have a 6 degree tilt down looking from the boat .
Dec 22, 2012 | Humminbird 561 Fishfinder
I did lost my operation manual for my fishfinder humminbird 570
Hi!
Since your unit isn't listed in their owners manual section, you'll have to contact their support rep.
http://www.humminbird.com/support/Contact_Support.aspx
Hope this helps you out.
Jun 20, 2011 | Humminbird Fishfinder 565 With Transom...
Mamual
hello there:
here is a few links that have the manual that you can download for free
  1. Humminbird 595C Manuals, Support and Troubleshooting - Fishfinder GPS Free download of Humminbird Fishfinder 595C User Manual. ... Humminbird Fishfinder 595C GPS. Need a manual? HUMMINBIRD 595C MANUAL ...www.retrevo.com/support/Humminbird-595C-GPS-manual/id/540ag515/t/2 - 96k - Cached
  2. Humminbird GPS Manual and Support Information: User Manuals: Retrevo ... largest collection of user guides and manuals on the web. ... Humminbird Fishfinder 595C. Operations Manual. Humminbird HDR 400G. User Guide. Humminbird HDR 400I ...www.retrevo.com/samples/Humminbird-GPS-manuals.html - Cached
Sep 16, 2009 | Humminbird 595c GPS Receiver
Humminbird 7300211 speed unit
Hi!
Installation of the speed/temp wheel is quite easy, here's a manual:
SW Speed & Temp
The new sensor cable plugs into the square plugin in back of your Humminbird....it's the small square connector with 4 holes.
Best of luck!
Mike
Apr 30, 2009 | Humminbird 7300211 SW Speed Sensor GPS...
Boating Logo
391 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
