Question about Frigidaire FER311FS Electric Dryer
Clothes get hung between tumbler tub and front of dryer and are scorched, what parts do I need to fix this?
  • Frigidaire Master
  • 8,220 Answers
You probably need a new glide kit on front panel
Unplug it and pop the topClothes get hung between tumbler tub and front of - a068344.jpg to get into the machine and take a look see. This is the most simple of all dryers to repair. It uses glides on front for the tub to ride on and it uses a hanger 3e1ec1c.jpgbearing in the rear for the drum to ride on. The plastic cup that the drum is cradled in wears down to metal to metal and can actually be cut in half causing the drum to drop down and lock up. This dryer is very easy to work on. MORE HERE
Posted on Jun 02, 2010
Makes scraping sound and clothes get hung up in front of drum. What parts need to be replaced?
When clothes get hung up in the space between the drum it means the seal is bad - probably your unit has glides that have worn (rollers make a banging noise)
Glides require removing the front of the dryer and pop riveting in new ones.
Go to searspartsdirect.com and enter your model number found on the dryer door jam (hidden when the door is closed). You can see the construction from the parts diagram
Sep 04, 2011 | Dryers
We have a Maytag Electric Dryer, Model LDE512 , which leaves black marks on clothes while drying them. The dryer is about 18 yrs. old and has been working great except for this one problem. We have...
HI The drum is mostly stainless steel; The end that contacts the drum guide is just painted steel. After years of rubbing, some rust can form after the paint wears away,thus, causing the stain. Painting the bare metal (after removing all rust) and replacing the tumbler bearings,roller and roller shafts, will correct this issue and prevent it form happening in the future. You should also replace the tumbler seal while the unit is disassembled. Part numbers are below:
Tumbler bearings/Glides(You need two)- 306508
Roller - 12001541
Roller shaft - 6-3129480
Tumbler seal - 314820
Roller Shaft washer - 312535
Retaining Ring(shaft)- 410233
Jul 16, 2010 | Dryers
Clothes getting stuck
check the top drum slides and tub bearing slide support. it is made of plastic and when it or the slides wear out the drum will drop down enough for clothes to start snagging
http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=395857&ModelNum=NWXR483EG3WW&mfgModelNum=&ManufactureID=2&Selected=00125553i02&Position=3&mfg=GE&Type=&Mark=3
May 28, 2010 | Hotpoint Ariston NWXR483EGWW Electric...
Clothes get hung or catch in the dryer and buttons get torn off or the clothes sometimes get scorched. I have a 2 year old Frigidaire front loader. Model # LEQ2152EE0. Any advice -- other than buy a new...
I believe your problem is worn out drum glides. You should examine the drum to see if the paint is not worn off where the glides make contact. A loss of coating there will accelerate wear on the new replacement glides. Also the bearing at the rear of the drum should be inspected and replaced if worn, or re lubricated if serviceable. The bearing should be a simple ball and socket assembly.
May 19, 2009 | Frigidaire Dryers
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FER311FS Electric Dryer Logo
172 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
