Question about Kenmore 63952 Electric Dryer
Kenmore dryer will stop in mid cycle and beep 3 times in succession. What does that mean? Already had a repairman out and he replaced the circuit board.
  • Kenmore Master
  • 8,220 Answers
Use some windex to clean the wax buildup off the dryer sensors under the filter housing inside the dryer.Kenmore dryer will stop in mid cycle and beep 3 - 9bc0002.jpg Autodry VS electronic sensing: First, wet clothes are electrically conductive. With electronic sensing dryers as the wet clothes tumble, they touch the two metal bars in the drum. (Auto dry dryers utilize a system of cycling the timer motor with the element, and has nothing to do with how wet the clothes are by the way.) There is a capacitor on the control that is trying to build up a charge, but when wet clothes create a short from one bar to the other, this charge is released to the frame of the dryer, therefore discharging the capacitor. As long as the capacitor charge is low, the control knows the clothes are wet. As the clothes become dryer, they short the bars fewer and fewer times. Once the capacitor charge builds to a certain level, the control knows the clothes are mostly dry, and it advances the program to the final timed portion, usually less than 20 minutes, some of which is a cool down portion to reduce wrinkling. If your dryer is shutting off after only 10 minutes, that means the control capacitor is never getting discharged. This can be due to a few different reasons: 1. Sensing bar wire is disconnected or broken; 2. Load is not large enough (remember the bars must be contacted repeatedly); 3. Bars are "coated" by fabric softener build up and need to be cleaned with Windex or 409. 4. Defective control board. 5. Airflow is restricted and moisture can't escape the drum. 6. Corrosion built-up on sensing board connection.(yank out the board and clean the contacts that sometimes is all it takes) Address the airflow condition and load size. Clean the sensor bars and make sure the wires are all connected securely. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel on many models. No sensing bars means you have auto-dry a totally different animal. Typically an orange wire is connected to the high limit on the heater element housing which feeds the timer motor when the element is not in operation. Bad control thermostat or air restrictions are the Autodry type dryer's worst enemy. Special thanks to a.g.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 02, 2010
My dryer stops midway through drying the clothes. I replaced the fuses.
Posted on Mar 20, 2011
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Kemore 65962 stops mid cycle
The circuit panel could be at fault
Mar 26, 2013 | Kenmore 659 Electric Dryer
Electric dryer stopped in the middle of a cycle of towels (or after they were dry...not sure, as renters reported problem). . There appears to be no current..panel does not light at all Have reset the...
My 4 yr. old Maytag electric dryer stopped in the middle of drying towels and wouldn't restart. I called one repairman who told me it was my motor and I called another repairman closer to where I live and he came out and replaced my fuse. My dryer works fine now.
Aug 17, 2011 | Kenmore 63942 Dryer
Kenmore Dryer does not run at all
I would start at the door limit switch. Bridge it out and try and run. Sometimes there is a switch on the tensioner lever that tensions the belt .If it does not make circuit, the system wont run as well.
Sep 21, 2009 | Dryers
KenmoreElite Dryer - beeps 2 short beeps rapidly and won't stop
call ur local repairman.. ur board could be fried!!!
May 18, 2009 | Kenmore Dryers
E1 comes on during mid cycle and stops the dryer from drying
replace the compressor "compressor relay and the compressor overload" that are on the side of the compressor.
location: should be in the back on the bottom behind the panel.
if you have a circuit board they may need to be replaced as well.
May 09, 2009 | Kenmore Elite HE4 Electric Dryer
It stopped mid-cycle..no warning, and wouldn't start again.
Unplug your dryer for ten min. This will reset the circuit board and reboot the system. Sometime small power surges can disrupt the curcuit and cause the unit to get confused. Rebooting usually will fix this type of problem with surges.
Apr 29, 2009 | Dryers
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
3 beep-tones
I am having this same problem, and it seems quite intermittant. I have finally narrowed it down to an electrical issue, somewhere on the control circuit board (which I have sitting in front of me right now.) I'm going to see if I can buy a new one, and for how much, before calling out the repairman.
Mar 16, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore 63952 Electric Dryer Logo
267 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
