Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Where is the hi temp limit switch located?
Where is the hi temp limit switch located on jandy LX
  • Betty Meyer Oct 05, 2011
    can you show me a diagrahm so I can find it the heater fan quit and the manual does not show what fuse to change
Where is the high temp limit switch located on my laars 44000 pool heater
Posted on Jun 03, 2010
Lx jandy 400 pool heater exhaust temp limit code on display, can this be bypassed to check
over heating check gas pressure and for burner tubes clogged and manual bypass in manifold spring
Oct 12, 2017 | Jandy Pool & Spa
How to chek hi limit switch
jump highlimit to see if it lights if so replace
May 27, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do i correct a "high limit switch circuit is open" code
check the fusable link for voltage on both sides if not replace also check pressure switch
May 26, 2014 | Jandy LX 400P Lo-NOx, 400,000 BTU Heater...
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy HI-E2 350K pool heater vent limit switch is resetting, flow is fast and good, but water temp is getting over 140 and kicking vent limit switch out
the vent switch is for the exhaust. the 135 high limit should be opening if the water temp is getting to 140 degrees.. 1 safety will kill the entire circuit since they are all wired in series
Oct 10, 2013 | Zodiac Jandy Hi-E2 350K BTU Residential...
How do u remove hi limit switch from a Jandy LX 400N-L heater model#LX400N-L
high limits are located at header where pipes go in underneath
if those are ok check fusible link maybe 2 one at bottom one at top under top cover
Aug 15, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My jandy lxi say's fault high limit switch..is there a test or bypass i can try
Yes you can jump past the limit switches one at a time. That will tell you which one is bad. Then you will need to replace it.
Sep 26, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Noticed water leaking a lot from bottom of unit. Looked like a pretty good leak. Unit is 9 years old. Leaks when Pump is running
More than likely the heat exchanger. Has the pH and Total Alkalinity been low? Check the Pressure/Temp relief valve, thermostat probe, high limit switches, etc. first though...
Jun 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Hi limit switch code showing. What do i need to do
This is most likley a water flow problem. If you have an external by-pass this should be almost closed. If not not you may have a problem with your internal by-pass. This is inside your water header on the heater. Your book can help you with this.
Oct 17, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Hi limit switch code,on a laars lx pool heater, I think there is a manual reset somewhere. can anyone help?
mine were corroded, but passed a continuity test. removing the corrosion opened a hole in one of the cases. $30/ea to replace (parts only). then i read how the brass 'screw' they contact with are prone to corrosion (salt pool), not listed in the parts manual, but are available as part# R0383200 (another $6/ea). not a happy jandy/laars/teledyne owner.
Jun 09, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
1,467 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
