Question about Samsung VP-D361 Mini DV Digital Camcorder
Tape eject door will open but tape will not eject
Got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Posted on Apr 10, 2008
I have a camcorder and the tape door will not shut and do down? is my camcorder broken?
Posted on Jun 06, 2008
MHC1500 Sony tape player is stuck! got deck door open, but tape will not eject. does not appear to be any loose tape. How can I get the tape cassette outf?
Prying the door open is not the first thing that should have been done. The mechanism for the tape transport is having a problem in that it either need service or the belt is too loose. A Technician would open the deck get the mechanism in the stop mode and then eject the tape. Any other way just damages the unit and might make it unrepairable.
Feb 14, 2013 | Audio Players & Recorders
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
Won't Eject Tape
same problem, after you hit eject is pops out and never opens up, to the right of the "push" button is an arm with a spring, pushing it back will open that side, on the left side is a pin with an arm you can move the arm back the pin moves and the other side will open as well, wont fix the problem but will get you your tape back.  I have a very upset wife, we had a jvc mini DV went out one winter change in temp killed it instantly, now our canon has sat a few years and wont work either,  we bought a flip video, it works.
Oct 06, 2008 | Canon ZR60 Mini DV Digital Camcorder
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Gs36 tape door doesnt open
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
Oct 13, 2007 | Panasonic PV-GS36 MiniDV Digital Camcorder
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Tape door will not open
the tape eject door will not open there is currently a tape in the camcorder (panasonic pv-l559)
Jan 09, 2007 | Panasonic PV-L559 Camcorder
Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Dec 17, 2006 | Canon ZR10 Mini DV Digital Camcorder
Tape door won't open on eject?
Many times I've heard my tape will not eject,most of the time unpluging the unit from the wall for about 10 minutes and then plug it back in,this resets the microprocessor and it goes bak to normal and the tape ejects.I hope it works. Please rate this solution if it does.
Oct 17, 2006 | JVC BR-S822DXU VHS/S-VHS playback VCR
Samsung VP-D361 Mini DV Digital Camcorder Logo
285 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
